no safe boot possible
  • Playing with the deepsleep of my pytrack with sipy I managed to get into a loop that I can not get out of.
    Doing the hard reset pin 12 on 3V for one second, which used to work is not doing anything anymore
    What can I do to get the hand back on my cards??
    Thank you very much
  • @robert-hh
    To qoute the docs directly, " After reset, if P12 pin is held high (i.e. connect it to the 3V3 output pin), the heartbeat LED will begin flashing orange slowly. If after 3 seconds the pin is still held high..." suggesting that the pin should be pulled high AFTER reset.
    In fact I did get a flashing orange led, using this method.
    My problem was that it appeared to reset once I released P12. I released P12 because I did not want to go to the prvious OTA firware and only wanted to disable boot.py and main.py.
    @Martinn
    I am sure that I have P12 (and not GPIO12 or '12') as I get the flashing led..
    I haven't solved it yet. Just documenting for posterity.
  • @goldfishalpha Are you sure you have P12? As you have noted, documentation is pretty buggy and pinout description a mess. You might well have the wrong pin.
  • @goldfishalpha Pulling P12 high and then pushing the reset button should activate safe boot, which does not execute boot.py and main.py on boot. That's almost the same as typing Ctrl-F at the REPL prompt.
  • Just for the record, I had a similar issue with a LoPy on a Pysense board.
    I foolishly got it stuck in a while loop. Pulling p12 high as per the official documentation could not get me back into REPL to reflash the file system, i.e
    import os
    os.mkfs('/flash')
    Reinstalling the firmware with the 'Erase flash file system' option checked worked the end.
    Additional: This is not the first time that the official documentation has been wrong or incomplete.
    Maybe an update of docs is in order?
  • @robert-hh Sorted. I just had desengage the sequence number on my sigfox account.
  • @devinv Erasing flash erase all data, including any credentials that existed. But these will normally be restored when you do a firmware install through the Pycom updater. And that needs to work, because sometimes devices are in a state where only a full erase help.
    But you may also ask Pycom service. Maybe Sigfox requires another configuration step.
  • @robert-hh Is it possible that all what I did could create problem with my sipy sending messages to Sigfox?
    It doesn't work anymore.
    This was working before
    sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
    s.setblocking(True)
    s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
    s.send(bytes([0x01, 0x02, 0x03]))
    But not anymore.
    No messages arrives to my sigfox account!?
  • @robert-hh Thank you so much. I'm back on track.
  • @devinv Oh yes. You have to connect P2 to GND and press reset, to go in boot mode.
    esptool.py does not support the PIC boot mode setting, it uses the espressif mode switch, which is sadly not supported by Pycom hardware.
    And there is a more recent version of esptool.py here: https://github.com/espressif/esptool/tree/4dab24e1b28632d270adf7305fe0d008d1acee99
  • @robert-hh ok, I tryed this
    python esptool.py -p COM6 -b 460800 -c esp32 erase_flash
    esptool.py v2.0.1
    Got this
    esptool.py:2124: DeprecationWarning: inspect.getargspec() is deprecated since Python 3.0, use inspect.signature() or inspect.getfullargspec()
    operation_args,,,_ = inspect.getargspec(operation_func)
    then this for 30 seconds
    Connecting.....................................................
    (that takes 30 seconds...)
    and then
    A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
    Is there something else which has to be done before?
  • @devinv You should install the stable version. But besides that all is fine. I use verison 1.15.2 of the updater. Links are here: https://forum.pycom.io/topic/3425/new-beta-firmware-updater-1-15-2-b0
    But firmware-wise the results are the same.
    As next step, try erasing with esptool.py & reflash. That is the crowbar style of reset and brings the device definitely back to the manufacturing state after assembly.
  • @robert-hh As I don't see the options you are talking about I'm not sure I'm using the right tool
    Following your link I used pycom_firmware_update_1.15.1.exe.zip
    There is no advanced section
    There is "Include developement releases", which I don't know if I need to tick or not (tryed both, same result)
    In the Communiction section I choose the PORT (COM6), the Speed (115200)
    I have the option 'erase flash file system' (which I ticked)
    Force update Lora region (I have a sipy, so I don't tick that right??)
    A 'flash from local file' option
    A type (pybytes, stable or development), which one do I have to choose?
    It asks for a pybytes activation token (no idea where I'm supposed to get that?). I can skip that part
    Then it instal 1.18.1.r7 [pybytes] and it mentions it is Sipy
    and it write after a few minutes : Your Sipy was successfully updated
    But then, nothing change I have the same
    flash read err, 1000 loop in Atom
  • @devinv I suggested to reinstall the firmware using the pycom firmware updater at https://pycom.io/downloads/.
    When you run the downloader, you can select "show advanced seeting" first, an the on one of the next pages you have the option to erase the file system too. verify on that page, that the proper device is shown.
    If all is OK, that should bring you to an clean device.
    Another method of erasing flash completely is using esptool.py from https://github.com/pycom/pycom-micropython-sigfox/tree/master/esp32/tools. The call is:
    python3 esptool.py -p <your_com_port> -b 460800 -c esp32 erase_flash
    After erasing with esptool.py, you can reload the firmware using the pycom updater.
  • @robert-hh So what do I do now?
    I can not upload anything.
    And when I press reset it is definitly trying to launch something.
    What can I do with the tiny basic interpreter? It doesn't let me do any command?
    How can I go back to a normal state where I can upload things are input basic commande?
  • @devinv it was 'erase flash'. The promt you see now after Ctrl-C is from an embedded tiny basic interpreter in the boot ROM.
  • @robert-hh erase iprion?
    I don't know what you mean. I launched the Pycom Upgrade
    and then got this from the Atom
    Connecting on COM6...
    ets Jun 8 2016 00:22:57
    rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
    rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8028,len:8
    load:0x3fff8030,len:1728
    load:0x4009fa00,len:0
    load:0x4009fa00,len:14592
    entry 0x400a059c
    Starting theets Jun 8 2016 00:22:57
    rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
    Falling back to built-in command interpreter.
    OK
    I can manage to break it with Control C
    but I get the
    CWhat?
    And there is nothing I can do unless rebooting and starting again.
  • @devinv you can always re-flash the firmware using the pycom updater. If you select the erase iprion, then you have a clean empty device. Obviously that will also delete all files.
