SigFox with Sipy not working anymore
 Hi, After all my problems, Deepsleep, pytrack, cleaning flash memory, reloading firmware
 I now realise that my Sipy is not sending anything to Sigfox anymoreWhen I tryed something as basic as sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1) s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW) s.setblocking(True) s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False) s.send(bytes([0x01, 0x02, 0x03]))I have no errors, got 3 as answer
 But on my sigfox page, no messagesit was working fine a couple of days ago, before all my flashing and firmware reupload the Sigfox Id hasn't changed What can I try to get it back?
 @eric73 Yes, the sequence was exactly my problem. Disengaging solved it :)
 Have you check the Token validity in sigfox backend 'informations' page, perhaps your device is out of contract (check creation date)?
 Have you check in event in sigfox backend if you have an invalid sequence number event ? then you have to do a 'disengage sequence number'
 Have you check the antenna connector ?
