    gpy file system
    os.renamegpy
    11 Posts 2 Posters 1.1k Views 2 Watching
    • K Offline
      kjm
      I've been frustrated in my attempts to do file handling in micropython on the gpy. Basic functions like os.rename are not available. I decided to see what others might be doing. https://github.com/Bucknalla/resin-pycom-ota is a pycom project. At https://github.com/Bucknalla/resin-pycom-ota/blob/master/Pycom/1.0.0/flash/lib/OTA.py line 70 I see os.rename(new_path, dest_path) WTF! are there better versions of os on other pycom devices different to whats on the gpy?
        robert-hh @kjm
        @kjm if you enter the commands:
        import os
        dir(os)
        you should see all commands that are supported. Looking at the sources, there is no difference in os or uos between the various Pycom modules. So your difficulties must be cause by something else, like the target file exists, or wrong spelling/coding of os.rename(). Try to retype it.
        What is exactly the error which you get?
        • K Offline
          kjm @robert-hh
          @robert-hh Tnx Rob, my bad, a typo. I'm trying to reuse an OTA directory updater from an Rpi in the gpy. I've been lucky enough to find some code snippet alternatives online for cmds like os.copyfileobject but replacements for the likes of os.rmtree still elude me, mostly because they in turn need path or walk.
          1. Is it possible to customise os to add missing cmds?
          2. Is there something like dir(os) that shows what python cmds are available on the gpy? I can't seem to get tarfile.open() to work
          >>> tar = tarfile.open('/flash/100.tar')
          NameError: name 'tarfile' is not defined
            robert-hh @kjm
            @kjm for the builtins set of names and commands, you can use:
            import builtins
            dir(builtins)
            For the set of modules you have to use the documentation. help("modules") is not implemented in the Pycom branch of micropython.
            • K Offline
              kjm
              @robert-hh Any chance of a link to the modules docs Rob?
                robert-hh @kjm
                @kjm It's possible & requires a firmware change. At the end, it looks like:
                >>> help("modules")
                MQTTClient        gc                sqnscodec         uio
                MQTTConst         hashlib           sqnscrc           ujson
                MQTTDeviceShadow  json              sqnstp            umachine
                MQTTLib           machine           sqnsupgrade       uos
                MQTTMsgHandler    math              ssl               upysh
                MQTTShadowManager micropython       station           uqueue
                __main__          mount             struct            ure
                _boot             network           sys               uselect
                _main             os                time              uselect
                _thread           pycom             ubinascii         usocket
                array             pye               ubinascii         ussl
                binascii          queue             ucollections      ustruct
                builtins          re                ucrypto           utime
                cmath             reload            uctypes           utimeq
                crypto            select            uerrno            uzlib
                errno             socket            uerrno            websocket
                framebuf          sqnsbrz           uhashlib
                Plus any modules on the filesystem
                Edit: I made a PR for that.
                  robert-hh @kjm
                  @kjm There is some of a tarfile implementation here: https://github.com/micropython/micropython-lib/tree/master/upip
                  Maybe that helps.
                  • K Offline
                    kjm @robert-hh
                    @robert-hh This is never gonna install on the gpy with cmds like mkdir -p ~/.micropython/lib/ in it Rob
                      robert-hh @kjm
                      @kjm The files of interest are upip.py and upip.tarfile.py. They run on an ESP32 and ESP8266 with MicroPython from micropython.org and should be mostly compatible to the Pycom branch.
                      • K Offline
                        kjm @robert-hh
                        @robert-hh So I'm looking for alternatives to tar=tarfile.open & tar.extractall Rob:
                        upip.tarfile.py is an tar opener maybe? How would anyone know since the author gives no clue on what it does or how to use it?
                        upip.py is looking like an extractor maybe? But it's only for specialist code not just any tar "Note: only MicroPython packages (usually, named micropython-*) are supported for installation, upip does not support arbitrary code in setup.py."
                          robert-hh @kjm
                          @kjm upip is meant to install (micro)python packages on a micropython device. So it downloads and extracts micropython packages. You have to tell yourself whether it is useful for you. But at least it is a good example. Paul is an excellent Python specialist and programmer.
                          There is a upip.help() telling how to use it. And upip.tarfile is, as far as I understand it, the tarfile extractor.
