    Any working examples of an HTTPS web server?
    wipy 2webserverhttpstls
    2 Posts 1 Posters 585 Views 2 Watching
      tshead
      Like it says, I’m interested in running an https web server on a WiPy 2, and having trouble connecting. Things work fine with plain http. Here’s my sample code:
      def http_server():
              bindsocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM, socket.IPPROTO_TCP)
              bindsocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
              bindsocket.bind(("0.0.0.0", 443))
              bindsocket.listen()
              while running:
                  connection, client = bindsocket.accept()
                  connection = ssl.wrap_socket(connection, keyfile="/flash/cert/key.pem", certfile="/flash/cert/cert.pem", server_side=True)
                      line = connection.readline()
                      if not line or line == b"\r\n":
                          break
                  connection.write("HTTP/1.1 200 OK\r\n")
                  connection.write("Content-Type: application/json\r\n")
                  connection.write("Access-Control-Allow-Origin: *\r\n")
                  connection.write("\r\n")
                  connection.write('{"temperature/ambient": {"value": %r, "units": "degC"}, "humidity/ambient": {"value": %r, "units": "RH"}, "pressure/barometric": {"value": %r, "units": "Pa"}}' % (data.temperature_ambient, data.humidity_ambient, data.pressure_barometric))
                  connection.close()
                  flash(0x00ff00)
              print("http_server stopped.")
      When I connect with a web browser, I’m prompted to accept my (self-signed) certificate so something’s working right, but the connection hangs. On the WiPy side, I get the following backtrace:
      Unhandled exception in thread started by <function http_server at 0x3ffe81a0>
        File "server.py", line 53, in http_server
      OSError: -1
      Line 53 is where I’m wrapping the socket:
      Any thoughts?
      Thanks,
      Tim
        tshead
        Following-up … if I add an exception handler and keep trying to connect, I get a bunch of different error numbers:
        Uncaught exception: -17168
        Uncaught exception: -10368
        Uncaught exception: -32512
        Uncaught exception: -29312
        Uncaught exception: -16
        Uncaught exception: -4480
        Uncaught exception: -19840
        Uncaught exception: -16912
        Any advice on how / where to look those up?
        Cheers,
        Tim
