pin performance
hi,
i have tested pin read performance
and it is like this:
read 1000 times pin value:
20558
21this is my test file
from machine import Pin import time dht_pin=Pin('P9', mode=Pin.OPEN_DRAIN, pull=None) am = time.ticks_ms() au = time.ticks_us() #comment this line if you have not enabled this in firmware for i in range(1001): dht_pin() print(time.ticks_us()-au) #comment this line if you have not enabled this in firmware print(time.ticks_ms()-am)and i see that i can read one pin value in 21 us
but specification for e.g. dht11/22 is like this:Bit '0' : ~54uS Low and ~24uS High Bit '1' : ~54uS Low and ~70uS Highi see that i can miss high value because its duration is 24us
how can we improve pin read time?for test i enabled in firmware time_us()
but previously tested this without any change -
I see some possibilities in speed up things by batch read
I will try to write some code and back with results
