    Help with BME280 on Wipy 3.0 + Expansion Board 3.0
    wipy 3.0expansion boardbme280i2c
    3 Posts 2 Posters 524 Views 2 Watching
      Dezert754
      Hi there, so Im having some trouble with the BME 280. I have already tried the following bme280 libraries :
      https://bitbucket.org/oscarBravo/wipy_bme280(Currently using this)
      https://github.com/catdog2/mpy_bme280_esp8266 (Just because it worked on my pyboard).
      I keep running into the same issue every time. Using normal code in .py doesn't work period. So I tried to do a work around multiple ways with REPL based on what other people said about Lora and Wipy 2.0 however I keep running into the same issue:
      from machine import I2C
      >>> from bme280 import *
      >>> i2c = I2C()
      >>> bme280 = BME280(address=0x76, i2c=i2c)
        File "bme280.py", line 149, in __init__
        File "bme280.py", line 155, in _load_calibration
        File "bme280.py", line 115, in readU16LE
        File "bme280.py", line 98, in readU16
      TypeError: function missing 1 required positional arguments
      or
      >>> import bme280
      >>> i2c = I2C(0, I2C.MASTER, baudrate=100000)
      >>> i2c.scan()
      [118]
      >>> bme = bme280.BME280(i2c=i2c)
      Its always the same lines that are being the issue. But I know that the sensor works because I use it with my Pyboard. I am also running:
      Pycom MicroPython 1.18.0.r1 [v1.8.6-849-9569a73] on 2018-07-20; WiPy with ESP32
      Any help is greatly appreciated!
        robert-hh @Dezert754
        @dezert754 You could try this one: https://github.com/robert-hh/BME280
        I adapted them from the Adafruit files to PyCom devices. There are two variants: bme280_float.py and bme280_int.py.
        The API is the same, just the internal calculation method differs, resulting very small differences between the variants (like 0.01%).
          Dezert754 @robert-hh
          @robert-hh Works like a charm, thank you so much!
