    [QUESTION][BOTTLE][FLASK][DJANGO] About web frameworks and SD
    flaskdjangobottlesd cardwebserver
    8 Posts 3 Posters 798 Views 3 Watching
    • N Offline
      nervencid
      Hello:
      Actually, I just bought a new pycom board and i wonder if it is possible to:
      1)Use web frameworks like Django (https://github.com/django/django/tree/master/django/db/models), flask (https://github.com/pallets/flask/tree/master/flask) or bottle (https://github.com/bottlepy/bottle), considering the last one is just one .py file, in order to create a simple web server?
      1. If i bought an expansion board with a micro SD... Can i store in said SD card .python files, javascript files or html in order to be imported to the board?
      2. Its possible to install some database inside a SD card in order to be used for the board?
      Thank you
        robert-hh @nervencid
        @nervencid Some notes:
        ad 1) None of them will work without major rework. These applications are made for a machine with full OS and full Python implementation. But there are a few Micro web servers around which you can use, like this one: https://github.com/jczic/MicroWebSrv in combination with https://github.com/jczic/MicroDNSSrv.
        ad 2) Micropython allows the usual file access methods to the SD. You can run python scripts from the SD and use that for data.
        ad 3) Yes. If you have a database script, it can use the SD. Unlike the micropython.org branch, the Pycom branch does not include a database module by default.
        N 2 Replies Last reply Reply Quote 1
        • N Offline
          nervencid
          • N Offline
            nervencid @robert-hh
            @robert-hh nervencid less than a minute ago
            Hello and thank you for your answer:
            By "None of them will work without major rework", you mean that at least bottle would work fine on the board?
            Thank you
              @nervencid No. If you look at the code of bottle, there are about a dozen libs which are imported by bottle which do not exist in Micropython. And there exists no run-time environment like the one assumed by the code,
              • N Offline
                Hello @robert-hh and thank you for your response:
                So, apart of that two frameworks is it impossible to set up a server on the board?
                  @nervencid You can set up aserver on the board. There is nothing that stops you to do so. Only you cannot expect that code that is intended for a windows or linux based machine will work. These are Micro's and MicroPython, and so you need a Micro Server.
                    Paul Thornton
                    You can try something like this: https://github.com/jczic/MicroWebSrv looks like the author explicitly supports pycom modules.
                    (Please note this isnt an official pycom recommendation. I've never used it. we dont support the library. I just found it in my travels and thought it might be usefull)
                    @jczic if you happen to stumble across this. Good work. Look's like a neat project!
