    Calling functions in uMQTT
    umgttmqttmicropythonadafruit iowipy mqtt
    4 Posts 2 Posters 555 Views 2 Watching
      Dezert754
      So I tried sending some data to Adafruit IO. I followed the guide created by Chris from core electronics located here. All his code works perfect, I can turn on and off my LED and the random data is sent fine. However I tried to add some of my own functions and it seems that they are not called.
      I am used to the python way of creating and calling a function:
      def some_random_function
          print("Apples!")
      some_random_function()
      However the umqtt doesn't feature anything like that so it looks like chris' functions get called automatically.
      So I attempted to create my function following what he did, however my function doesn't even get called as I dont get my first print statement.
      def send_bme():
          print("Wipy trying to send: ", bme280.values)
          try:
              client.publish(topic=AIO_BME_FEED, msg=str(bme280.values))
              print("Success!")
              time.sleep(5)
          except Exception as e:
              print("Failed!")
              time.sleep(5)
        Paul Thornton
        I took a quick glance at the code you linked.
        Looks like he calls his send_random function from the main loop each time.
        You'll need to do the same to have yours called
        while 1:              # Repeat this loop forever
                client.check_msg()# Action a message if one is received. Non-blocking.
                send_random() #here.
                some_random_function() #add a call to your function here
          Dezert754 @Paul Thornton
          @paul-thornton Thanks very much! So obvious, I dont know how I missed that, haha.
            Paul Thornton @Dezert754
            @dezert754 We've all had those moments :P glad its all sorted.
