    pycoproc.py and Expansion board 3
    expansionboardpycoproc.pydeepsleeplopy4
    2 Posts 2 Posters 384 Views 2 Watching
      Giorgio
      The Expansion Board 3 (alone) requires 3.8mA (--> read on the multimeter) and I have read that it depends on the PIC on the Exp. Board that remains active even if the Lopy4 (that I use) is in machine.deepsleep.
      I have also read that the pycoproc.py library can be used in order to put in power down the PIC.
      1: is it right?
      2:can anyone help me and give an example on how to do it? (for expansion board 3 and not for Pysense or pytrack).
      Thanks a lot for your help
      F 1 Reply Last reply Reply Quote 0
      • F Offline
        Fakstory @Giorgio
        @Giorgio Did you find out how?
        I have the same problem here, using a gPy+Expansion Board V3.1. I can't find a way to put the board in deepsleep mode. It is currently using 14mA. I can only find documentation for Pysense/Pytrack/DSboard, etc.. but nothing for the Expansion Board!? :\
        Where's the info I am missing?
        Fakstory
