    Expansion board 3.1 : Powering off LiPo
    expansion boardbattery poweredboot
    6 Posts 4 Posters 881 Views 4 Watching
      DomGiles
      I'm struggling to get the to boot from when powered from a Lipo. My code and the Expansion board works fine when powered by USB. The battery is fully charged with a voltage of 4.1v. I've tried connecting P8 to 3.3v (as indicated in the pin out) to pull it high but that doesn't seem to make any difference...
      The LED comes on but that's it.
      Am I missing something obvious?
        robert-hh @DomGiles
        @domgiles This is a often mentioned "feature" (some nasty people call it a bug). Try to pull up P8 with a resistor of 4.7 to 10 k to 3.3V.
        D P 2 Replies Last reply Reply Quote 1
          DomGiles @robert-hh
          @robert-hh said in Expansion board 3.1 : Powering off LiPo:
          Still no luck. Tried 4.7k and 10k. Still won't start. Works fine when powered by a Adafruits power boost 500c to vin.
          I only have a few sensors hanging off the back as well... Shame. Feeling very underwhelmed by the testing that goes on some of the expansion boards. I would make the case that if you allow a battery to be attached to an expansion board, there's a reasonable expectation that it should be able to power it.
          Same with the sensor board. There's a reasonable expectation that a temperature sensor would measure the ambient temperature without having to worry the controller hadn't been running for a while etc. I'm going to have to give up on them. They feel like they all need another rev with some additional QC love and some decent documentation.
            pac_71 @robert-hh
            @DomGiles I have the same problem with a Lopy4 & Expansionboard 3.1. It boots okay when powered from USB, works okay once USB is disconnected and operating on 3.7v Lipo but wont restart after reset on battery only.
            @robert-hh Thanks for the tip. I tried a direct jumper between P8 and 3.3V and only got flashing Orange/Power LED. I have some resistors on order now to try the pull down.
            For a poor mechanical engineer.
            A pull up means a resistor between the 3.3V pin and the P8 pin (as marked on the Expansion Board 3.1). You would then connect a switch between P8 and GND to pull it low when closed if you were using this as a logic circuit.
            Conversely, A pull down would be a similar resistor between P8 pin and GND. To make sure there is 0V at P8. You would then have a switch to 3.3V for a high when closed signal.
              robert-hh @pac_71
              @pac_71 No. A Pull-Up resistor connected between P8 and 3.3 V dose not require extra action. At a value of 4.7k or 10k, some other units, the ESP32 or a logic output of an external device, can drive it low when needed. No switch is required. P8 is also used for the SD card. So connecting it directly to 3.3V would block the SD card.
              • N Offline
                nestorld
                This is an old topic but would like to add some comments that can be useful to someone having this kind of issues. I have an expansion board 3 with a Wipy, using the SD card and some sensors, and everything is working well being powered throu USB or battery. I had some issues that were fixed by following these steps:
                • When powered by battery, P19 and P20 are affected by RTS and CTS respectively, and it was blocking one sensor I have connected to those pins. Removing those jumpers from Expansion Board resolved this issue.
                • Don't use P8 with any sensor if you are using SD card. Looking at the Wipy3 pinout, I suppose the same is true for P3, P9 and P10. Even thou, P10 is also connected to the user button, then I configured it as an input pin with pull=PULL-UP, and avoid read/write SD operations and user button clicks at the same time.
                • Also, this post helped me with a weird behavior of user button when using the battery: https://forum.pycom.io/topic/7364/exp-board-user-push-button/3?_=1648562954689
                • I connected the 10K pull-up resistor to P8 as indicated in the expansion board documentation, but honestly, I don't understand why it's needed.
                Most of these "tricks" are not clearly documented and I found them reading several posts and connecting ideas between them. In my opinion, Pycom boards are very good in general (with a very few details that could be improved), but as said in many places, its documentation should be reviewed to add many things like these that one has to chase reading somewhere else or by try/fail methods.
                Néstor López
