    is pycom.rgbled thread safe?
    threadaws mqttmqtt
    1 Posts 1 Posters 315 Views 2 Watching
    • M Offline
      Martinnn
      I modified the Pycom AWS MQTT library and put an LED blink into the transmit routine:
              self._out_packet_mutex.acquire()
              if self._ping_failures == 0:
                  if self._out_packet_mutex.locked() and len(self._output_queue) > 0:
                      packet=self._output_queue[0]
                      pycom.rgbled(0xff0000) # red
                      if self._send_packet(packet):
                          self._output_queue.pop(0)
                          if self.wdt is not None:
                              self.wdt.feed()
                          pycom.rgbled(0x000010) # dark blue
              self._out_packet_mutex.release()
      Also, I feed the WDT here so the Wipy gets a reset in case of a connection loss. As the MQTT library starts a thread for this transmit routine and I also set the LED from the main code (running in parallel), could there be the case that the main code is interrupted while executing a pycom.rgbled and then pycom.rgbled be called in the transmit thread? Is it safe to do so? Or would I need to encapsulate the LED update with another mutex?
