    pyscan can not read the nfc tag
    pyscannfcdata
    2 Posts 2 Posters 374 Views 2 Watching
    • M Offline
      mia1913
      I uesd the code of pyscan library, and ran the code named nfc.py. When the nfc tag touched the nfc antenna, I counld only got an incomplete (4 byte) uid, which actually has 7 byte uid. Onther data in fan sectors, ,such as URL, written in the nfc tag can not be read. The function of nfc.mf630_MF_auth reading sector data never successed. I am not sure the reason for it. The type of nfc tag is ISO 14443-3A, NXPMIFARE Ultralight C.
      Can anyone give me suggestions? Thank you.
      Mia CHEN
        jcaron @mia1913
        @mia1913 don’t know the details of the interface / library, but at a low level, 7 and 10-byte UUIDs are actually transmitted in several round trips.
        For a 7-byte UUID, only 3 bytes of the UUID are returned, and the other byte is a special value which means “there’s more”. You then do another request which returns the remaining 4 bytes.
        No idea how this is/should be handled on the Pyscan, though.
