    RMT, receiving is working fine however transmitting seems to fail
    wipy 2.0rmtinfrared
    1 Posts 1 Posters 254 Views 1 Watching
    • B Offline
      bnjroos
      I have been playing around with an IR receiver and an IR transmitter, I have no issue recording the signal from my AC remote (Panasonic) however when I try to transmit I seems to be erratic and not transmitting everything.
      I am using two WiPy, one to receive and one to transmit.
      To receive/record:
      # create a RMT object
      rmt = machine.RMT(channel=4)
      # Configure RTM for receiving
      rmt.init(gpio="P21", rx_idle_threshold=12000)
      # wait for any number of pulses until one longer than rx_idle_threshold
          data = rmt.pulses_get()
          print('length:%s' % (len(data)))
          print(data)
      From the remote the output is as followed:
      length:128
      ((0, 3458), (1, 1769), (0, 397), (1, 500), (0, 366), (1, 1340), (0, 419), (1, 475), (0, 394), (1, 472), (0, 393), (1, 475), (0, 367), (1, 498), (0, 367), (1, 500), (0, 367), (1, 501), (0, 367), (1, 500), (0, 394), (1, 472), (0, 397), (1, 472), (0, 392), (1, 500), (0, 368), (1, 499), (0, 398), (1, 1307), (0, 397), (1, 498), (0, 367), (1, 476), (0, 391), (1, 500), (0, 368), (1, 499), (0, 396), (1, 448), (0, 415), (1, 475), (0, 367), (1, 499), (0, 366), (1, 1340), (0, 420), (1, 1316), (0, 420), (1, 1313), (0, 392), (1, 501), (0, 422), (1, 472), (0, 392), (1, 1315), (0, 394), (1, 500), (0, 366), (1, 500), (0, 368), (1, 499), (0, 368),
      (1, 499), (0, 395), (1, 449), (0, 391), (1, 499), (0, 367), (1, 500), (0, 367), (1, 476), (0, 391), (1, 500), (0, 392), (1, 475), (0, 391), (1, 475), (0, 367), (1, 499), (0, 368), (1, 499), (0, 424), (1, 470), (0, 368), (1, 499), (0, 368), (1, 499), (0, 368), (1, 499), (0, 366), (1, 501), (0, 367), (1, 500), (0, 395), (1, 472), (0, 368), (1, 498), (0, 368), (1, 499), (0, 368), (1, 499), (0, 390), (1, 478), (0, 392), (1, 474), (0, 395), (1, 472), (0, 393), (1, 473), (0, 396), (1, 472), (0, 419), (1, 475), (0, 396), (1, 470), (0, 394), (1, 1312), (0, 396), (1, 1338), (0, 422), (1, 472), (0, 390), (1, 478), (0, 392), (1, 474), (0, 394), (1, 472))
      If i try to send this code using an IR led from another WiPy with the following code:
      from machine import RMT
      record = ((0, 3458), (1, 1769), (0, 397), (1, 500), (0, 366), (1, 1340), (0, 419), (1, 475), (0, 394), (1, 472), (0, 393), (1, 475), (0, 367), (1, 498), (0, 367), (1, 500), (0, 367), (1, 501), (0, 367), (1, 500), (0, 394), (1, 472), (0, 397), (1, 472), (0, 392), (1, 500), (0, 368), (1, 499), (0, 398), (1, 1307), (0, 397), (1, 498), (0, 367), (1, 476), (0, 391), (1, 500), (0, 368), (1, 499), (0, 396), (1, 448), (0, 415), (1, 475), (0, 367), (1, 499), (0, 366), (1, 1340), (0, 420), (1, 1316), (0, 420), (1, 1313), (0, 392), (1, 501), (0, 422), (1, 472), (0, 392), (1, 1315), (0, 394), (1, 500), (0, 366), (1, 500), (0, 368), (1, 499), (0, 368),
      data = ()
      duration = ()
      for x in record:
          data = data + (x[0],)
          duration = duration + (x[1],)
      rmt = RMT(channel=4, gpio="P21", tx_idle_level=RMT.LOW)
      while 1:
          print('sending...')
          rmt.pulses_send(duration, data)
          print('done')
          time.sleep(2)
      I get random transmissions:
      length:25
      ((0, 564), (1, 330), (0, 208), (1, 818), (0, 559), (1, 370), (0, 654), (1, 263), (0, 850), (1, 187), (0, 436), (1, 288), (0, 558), (1, 571), (0, 695), (1, 11801), (0, 1012), (1, 312), (0, 374), (1, 274), (0, 207), (1, 573), (0, 1796), (1, 647), (0, 1194))
      length:7
      ((0, 265), (1, 156), (0, 284), (1, 183), (0, 202), (1, 174), (0, 205))
      Any idea what am I doing wrong ?
      Thank you in advance.
