    Passing one object to another
    pythonbluetooh
    1 Posts 1 Posters 263 Views 1 Watching
    • M Offline
      misterlisty
      I have created a logging class that works fine except when I wish to pass an instance of BLE class so that I can redirect the logs to BLE.
      oBLE = BLE(oConfig,devicename)
      oLOGGING = LOGGING(oBLE)
      oLOGGING.logger("config::oBLE[" + str(oBLE.enable) + "]",level=4)
      ****ERROR *** logger::Exception'NoneType' object has no attribute 'Write_log'
      class LOGGING:
          def __init__(self, oBLE):
              self.oBLE = oBLE
          def logger(self,msg,showtime=True,level=3,topic="",bdebug=True,debuglevel=3): #error0,warning1,debug2,info3,verbose4
              try:
                  self.oBLE.Write_log(msg)
              except Exception as e:
                  print("    logger::Exception" + str(e))
              if bdebug and debuglevel>=level:
                  if showtime:
                      print(" | ",msg)
                      print(msg)
                      # send_msg("outbox",msg)
      class BLE:
          global intRTCErrors
          def __init__(self,oConfig,devicename="devicename"):
              global bluetooth
              self.oConfig = oConfig
              self.bluetooth = Bluetooth()
              self.devicename=devicename
              self.char1_read_counter=-1
              self.BLEchr=None
              self.bluetooth.init()
              self.__enable = True # DEFAULT VALUE IF NOT FOUND IN NVMEM
              self.__started = False
              print("---START --- BLUEON  ------------------------------------------------")
              global chr1
              try:
                  # LOGGING.logger("CMD::BLEADVERTISE...")
                  global chr_light
                  global chr_temp
                  global chr_humidity
                  global chr_batt
                  global chr3
                  self.bluetooth.set_advertisement(name=self.devicename, service_uuid=b'1134567890123456')
                  self.bluetooth.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=self.BLE_connection_callback)
                  self.bluetooth.advertise(True)
                  # LOGGING.logger("CMD::BLEADVERTISE::Setup Service #DEEDAAFB-0000-0000-0000-000000000001")
                  srv1 = self.bluetooth.service(uuid=uuid2bytes('DEEDAAFB-0000-0000-0000-000000000001'), isprimary=True,nbr_chars=5)
                  chr1 =          srv1.characteristic(uuid=uuid2bytes('DEEDAAFB-0000-0000-000C-000000000001'),properties=Bluetooth.PROP_WRITE | Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value=self.devicename)
                  chr_light =     srv1.characteristic(uuid=uuid2bytes('DEEDAAFB-0000-0000-000C-000000000002'),properties=Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value=0)
                  chr_temp =      srv1.characteristic(uuid=uuid2bytes('DEEDAAFB-0000-0000-000C-000000000003'),properties=Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value=0)
                  chr_humidity =  srv1.characteristic(uuid=uuid2bytes('DEEDAAFB-0000-0000-000C-000000000004'),properties=Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value=0)
                  chr_batt =      srv1.characteristic(uuid=uuid2bytes('DEEDAAFB-0000-0000-000C-000000000005'),properties=Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value=0)
                  #chr1 = srv1.characteristic(uuid=b'ab34567890123456', value=5)
                  char1_cb = chr1.callback(trigger=Bluetooth.CHAR_WRITE_EVENT, handler=self.write_handler)
                  char2_cb = chr1.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=self.read_handler)
                  # LOGGING.logger("CMD::BLEADVERTISE::DRM Service #DEEDAAFB-0000-0000-0000-000000000002")
                  # srv2 =   bluetooth.service(uuid=uuid2bytes('DEEDAAFB-0000-0000-0000-000000000002'), isprimary=True)
                  # chr2 = srv2.characteristic(uuid=uuid2bytes('DEEDAAFB-0000-0000-000C-000000000002'),properties=Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value=str(wl.ifconfig()))
                  # char2_read_counter = 0xF0
                  # char2_cb = chr2.callback(trigger=Bluetooth.CHAR_WRITE_EVENT | Bluetooth.CHAR_READ_EVENT, handler=char2_cb_handler)
                  # LOGGING.logger("CMD::BLEADVERTISE::Command Service #DEEDAAFB-0000-0000-0000-000000000003")
                  srv3 = self.bluetooth.service(uuid=uuid2bytes('DEEDAAFB-0000-0000-0000-000000000003'), isprimary=True)
                  self.BLEchr = srv3.characteristic(uuid=uuid2bytes('DEEDAAFB-0000-0000-000C-000000000003'),properties=Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value="logging..")
                  char3_cb = self.BLEchr.callback(trigger=Bluetooth.CHAR_WRITE_EVENT, handler=self.BLE_CommandService_handler)
                  self.BLEchr.value("ble logging.....")
                  self.Write_log("bleuey more..")
                  intRTCErrors=0
                  print("ble::exceptiond " + str(e),level=1)
              print("---END --- BLUEON  ------------------------------------------------")
              return "BLEADVERTISE..DONE"
          def Write_log(self,slog):
              print("Blueit..",slog)
              self.BLEchr.value(slog)
