    WiPy 2.0 Captive Portal Network Config
    captive portalwipy 2.0dhcpdnsap mode
    5 Posts 4 Posters 745 Views 4 Watching
      soulkiller
      I was trying to implement a captive portal for the initial configuration of the device. I've been found some implementations on ESP8266 and ESP32 boards on the internet and decided to go with the below:
      https://github.com/Matt4/micropython-captive-portal-network-setup
      which uses DNS redirection method.
      I've faced some issues regarding network library in Pycom ( using firmware 1.15.1 ).
      • Ap mode is successfully initializes below code, but I've seen the IP of the board remains 0.0.0.0
      • When I connect my android phone to the board, WiFi details in android as -> IP: 1.2.3.5 / Gateway: 1.2.3.4 / DNS: 1.2.3.4 Subnet: 255.255.255.0 , so it is correct I believe.
      • On the android chrome when I enter the mock website address (asd.net), the redirection isn't happening.
        How it's possible to make automatic redirection to the captive portal, when a client connects to the board, am I missing something ?
      import network
      import usocket as socket
      import ure
        ap = network.WLAN(mode=network.WLAN.AP, ssid="wipy" )
        ap.ifconfig(id=1, config=('1.2.3.4', '255.255.255.0', '1.2.3.4', '0.0.0.0'))
        ip = ap.ifconfig()[0]
        print("DNS Server: dom.query. 60 in A {:s}".format(ip))                 # Prints- DNS Server: dom.query. 60 in A 0.0.0.0
        udps = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
        udps.setblocking(False)
        udps.bind(('',53))
        s = socket.socket()
        addr = (ip, 80)
        s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
        s.bind(addr)
        s.listen(1)
        s.settimeout(2)
        print("Web Server: Listening http://{}:80/".format(ip))                 # Prints- Web Server: Listening http://0.0.0.0:80/
        regex = ure.compile("network\?ssid=(.*?)&password=(.*?)\sHTTP")
        set_connection = False
        while set_connection is False:
          try:
            data, addr = udps.recvfrom(4096)
            print("Incoming data, from : ", addr)
            DNS = DNSQuery(data)
            udps.sendto(DNS.response(ip), addr)
            print("Replying: {:s} -> {:s}".format(DNS.domain, ip))               # Prints- Replying: beacons2.gvt2.com. -> 0.0.0.0
          except:
            print("No DNS")
          # Web server accepting connections
          try:
            res = s.accept()
            client_sock = res[0]
            client_addr = res[1]
            req = client_sock.recv(4096)
            print("Request:")
            print(req)
            client_sock.send(CONTENT)
            client_sock.close()
            print()
            search_result = regex.search(req)
            if search_result:
              incoming_network_name = search_result.group(1)
              incoming_network_pass = search_result.group(2)
              con = connection(incoming_network_name, incoming_network_pass)
              if con is True:
                d = {"network_name": incoming_network_name, "network_password": incoming_network_pass}
                f = open("config.json", "w")
                f.write(ujson.dumps(d))
                f.close()
          set_connection = True
          except:
            print("Timeout")
          time.sleep_ms(1000)
        udps.close()
      Thanks in advance
      -Baris
      PanometricP 1 Reply Last reply Reply Quote 0
        Paul Thornton
        @soulkiller said in WiPy 2.0 Captive Portal Network Config:
        1.15.1
        Hello @soulkiller,
        That firmware version is rather old now. a ton has been fixed in the networking area in later builds. Try giving this a go under 1.18. (latest stable). Hopefully you'll see better results.
          soulkiller @Paul Thornton
          Hello @paul-thornton , thank you for the reply. I've upgraded the firmware to 1.18.2, but still I get the same outputs.
          • PanometricP Offline
            Panometric @soulkiller
            @soulkiller , did you get this working? Can you share an example? Thanks.
              jczic
              I released a fully new version (v2.0) of my web server here : https://github.com/jczic/MicroWebSrv2.
              Open source MIT, fully asynchronous, more robust, more fast and more efficient on Pycom modules.
              It is delivered with a good documentation.
              For captive portal, you can use a simple DNS server here (see readme) : https://github.com/jczic/MicroDNSSrv
              Thank you for your support and feedback. ☺️
              JC`zic
