    How to display last traceback
    tracebackexceptionerror
    5 Posts 2 Posters 616 Views 2 Watching
      alexpul
      I'm looking for a way to display the latest traceback. I have a wipy that runs a script for a long time so I disconnect it from the REPL, which means that when an error occurs I can't see the line number where it occurred. Definitely makes debugging difficult! I know that sys.exc_info() gives the exception that occurred but I also need to know where it occurred. Ideally, I'd like to just display the last traceback in the REPL when I reconnect to the device and to avoid try/catch statements because the code is long. Any ideas?
        crumble @alexpul
        import sys
        except Exception as e:
            sys.print_exception(e)
          alexpul @crumble
          @crumble Thanks for the quick reply. Unfortunately the try/except method doesn't work after the error has occurred. If the device isn't connected to the REPL when the error occurs you cannot retrieve the traceback. I know you can save the exception to a file but I'd like to just print it in the REPL but after the error occurs.
            crumble @alexpul
            You can write the output of print_exception() into a file
            import sys
            try:
                raise ValueError('Hellas ', 1, 2, 3)
                f2 = open('/sd/exceptions.txt', 'a')
                f2.write('\nException at: ' + str(rtc.now()))
                sys.print_exception(e, f2)
                f2.close()
            reading it from REPL is not nice, but you can write a method for the UX
            e = f2.read()
            print(e)
            f2.close()
            The result will look like:
            Exception at: (2019, 2, 19, 19, 46, 19, 620384, None)Traceback (most recent call last):
              File "main.py", line 101, in <module>
            ValueError: ('Hellas ', 1, 2, 3)
            Exception at: (2019, 2, 19, 19, 54, 55, 351626, None)Traceback (most recent call last):
            I found an implementation of pickle, but it was not able to load string. So you can use only the output.
            A 1 Reply Last reply Reply Quote 2
              alexpul @crumble
              @crumble Not a bad work around! Thanks for your help.
