    If setup as a LoRaWan Nano gateway...
    lopy4gatewayfeather
    3 Posts 2 Posters 354 Views 2 Watching
      CoachAllen
      If setup as a LoRaWan Nano gateway, what is the added value of PyBytes?
      I did the setup and all seems well. But I am feeling like I am missing the point. I see the code for the gateway has some points where it could be printing to the console but I don't actually see anything in the PyBytes Terminal. Am I missing something.
      Also is the gateway even really needed? It seems to me that I have an added step of complexity if the LoPy4 is using the WiFi to communicate to PyBytes. I have a Feather 32u4 chip sending "Hello LoRa" to my gateway but I really don't see how this combination plays out with PyBytes.
      Sorry, these are all terrible rookie questions. Any help or guidance?
      Cheers,
        Paul Thornton
        The value added by pybytes becomes much more apparent from the node point of view not a gateway.
        Youll still get the remote management features which are always handy.
        But you likely wont be having a gateway sending signals to pybytes to log. acting as a gateway is one of the few use cases you can't really gain much in terms of added features using pybytes. I personally would use it for the remote terminal support alone.
          CoachAllen
          Fair enough,
          I did quite a bit of reading on TTN about Gateways, Nodes, Applications, etc...
          I think once I can muster up some more funds for an actual Gateway; I will convert this to a Node. This PyCom LoPy4 is really a learning experience for me. The idea of using MicroPython is all new to me.
          Cheers,
