    Software saveboot using P14 on Pytrack/Pysense
    Scheduled Pinned Locked Moved Projects
    boot.pysafeboothangspytrackpysense
    1 Posts 1 Posters 405 Views 2 Watching
      tvetter1976
      Quite often (depending on my code ) I had problems uploading code, accessing the REPL or connecting to the board. I found myself a solution using the Button on Pytrack/Pysense when starting up the divice after a reset. Instead of the main.py an altenative main.py ( main_save.py in my case) will be loaded. Here is my boot.py code. Mybe someone find it useful:
      from machine import Timer
      from machine import Pin
      from machine import main
      chrono = Timer.Chrono()
      chrono.start()
      i=True
      saveboot=False
      ##Timeout for pressing the button
      waitForSavebootTimeout=3
      ###Waiting for the buttonn to be pressed:  Green LED
      pycom.rgbled(0x005500)
      while i==True:
          if (Pin('P14').value()==0):
              saveboot=True
          lap = chrono.read()
          if lap>waitForSavebootTimeout  or    saveboot:
              i=False
      if   saveboot:
          ###entering save boot main_save.py will be loaded: Blue LED
          pycom.rgbled(0x000055)
          main("main_save.py")
      if   not saveboot:
          ###entering normal boot main.py will be loaded: Red LED
          pycom.rgbled(0x550000)
