New firmware release 1.2.0.b1
@daniel What does "Update the LoRaWAN stack to Semtech's version 4.3.0" mean. To my knowledge the latest LoRa Alliance LoraWAN specification is on version 1.0.2? Is the version number 4.3.0 related to some internal Semtech ESP stack implementation? The reason I am asking is that we are having troubles with LoPy´s running last firmware update (still investigating) on our LoRaWAN network.
@arneme said in New firmware release 1.2.0.b1:
Probably this
Probably this
https://stackforce.github.io/LoRaMac-doc/Yes, that's correct.
@arneme what problems are you experiencing?
@daniel The problems were related to "CRC failures", "FailedAuthentication" and problems with "Packets out of order". We are however not sure if it is a firmware problem or if we have a failing gateway in our network. Moving the devices to a location with a different gateway in reach seems to have solved the problem. We also did a restart of our network server and that could also have solved the problem. I will let you know if we see more errors like this.
@arneme OK thanks for the update. Please let us know when you know more.
i try to use pin callback
but how to check what cause callback?
e.g.:p_in.callback(Pin.IRQ_FALLING | Pin.IRQ_RISING, pin_handler) def pin_handler(arg): if need to know if raising: something when rising else: something when fallingchow to check in callback that it is executed because
a) IRQ_FALLING
b) IRQ_RISING
@livius good question, we are implementing that feature as we speak ;-)
@livius in the meantime, you can check the pin value inside the callback. If the pin is low, then most likely it was due to a falling edge, otherwise it was a rising edge.
@daniel We have now several LoPys up and running on our LoRaWAN network with version 1.2.0.b1 and they all behave as they should. The problem must have been with our infrastructure at the location we tested during the weekend.
@arneme great to hear that, thanks for the feedback :-)
