    VS Code Pymakr - The terminal process command failed to launch
    vscodevscode pymakrpymakr
    5 Posts 3 Posters 853 Views 3 Watching
      SmokeySpace
      I am trying to install Pymakr for VS Code, and I've used VS Code before but when I download this it doesn't stop giving me the error "The terminal process command "node.exe" failed to launch" (see picture below) and the whole program just freezes up and I can't do anything. I've tried reinstalling the extension, reinstalling VS Code, not using any other extensions, etc. But nothing seems to be working, any ideas?
        sarthak04
        Hello!
        First make sure you have NodeJS installed in your system.
        If the problem still persists, try downgrading your PyMakr version to v1.0.5
        I had faced the same issue while back, and this technique worked for me. You can try this too.
        • M Offline
          Milan
          @SmokeySpace I had the same issue. You should install NodeJS (https://nodejs.org/en/). After installation VS Code with Pymakr should work.
            SmokeySpace @sarthak04
            @sarthak04 thank you that worked!
              sarthak04 @SmokeySpace
              @smokeyspace No problem at all :)
