    Update to Pybytes firmware 1.18.2.r3 (solving device WiFi connectivity issues)
    7 Posts 3 Posters 1.1k Views 3 Watching
      jirkakrepl
      we released new Pybytes firmware 1.18.2.r3 which is solving WiFi connectivity issues:
      • the device becomes disconnected after several days.
      • the device won't re-connect to a WiFi network if WiFi access point was powered off at the time when the device booted up.
      • much stable WiFi geolocation
      Now in Pybytes library, a watchdog timer is being fed after a device receives a pong response from pybytes (device sends a ping message on WiFi every 10 minutes).
      If you have a device in a field which appears offline in Pybytes, now within 10 minutes it should be back online.
      EDIT:
      Because of a bug in Pybytes library there's a chance that your device will not automatically reboot after a successful WiFi OTA firmware update. Please reboot your device manually. We will make OTA updates more robust in the future.
      software developer @ Pycom
      S 1 Reply Last reply Reply Quote 3
        Steve Williams @jirkakrepl
        @jirkakrepl Will this be available automatically using the Pycom Firmware Updater or does it have to be downloaded from somewhere?
        I am having some WiFi connection issues so would be keen to try this, provided it doesn't introduce other issues..
          jirkakrepl
          Hi @Steve-Williams,
          firmware 1.18.2.r2 is now publicly available.
          You have two ways how to update your firmware:
          1. With Pycom firmware updater app:
            1. create new activation token for your device In Pybytes (device -> configuration)
            2. in firmware updater check "force update pybytes registration" and paste your new activation token
          2. WiFi OTA firmware update with Pybytes:
            • In pybytes go to your device -> settings - firmware
          • E Offline
            Eric Waai
            Error receiving MQTT. Ignore this message if you disconnected
            File "_pybytes_protocol.py", line 93, in __check_mqtt_message
            File "_mqtt.py", line 58, in check_msg
            File "_mqtt.py", line 56, in check_msg
            File "_mqtt_core.py", line 229, in check_msg
            File "_mqtt_core.py", line 216, in wait_msg
            File "_pybytes_protocol.py", line 123, in __recv_mqtt
            File "_pybytes_protocol.py", line 161, in __process_recv_message
            NameError: name 'machine' is not defined
            got this after updating the firmware via pybytes
            it did reconnect successful
              jirkakrepl @Eric Waai
              Hi, @eric-waai thank you for reporting this bug. I was able to replicate it, it seems to me too that the device remains connected to Pybytes. So probably there's just some edge case we need to fix to not throw this error after doing OTA.
              • E Offline
                Eric Waai
                i found out it actually didn't updated the firmware
                when i tried OTA again the device got stuck
                after a manual reset i get a checksum error
                Performing OTA
                Requesting: manifest.json?current_ver=1.18.2&sysname=FiPy&wmac=807d3ac263a8 to software.pycom.io:443 with SSL? True
                Wrapping socket
                Sending request
                Requesting: downloads/appimg/firmware_FiPy_1.18.2.r2.bin to software.pycom.io:443 with SSL? True
                Wrapping socket
                Sending request
                start
                7 [0]
                8 [0]
                9 [64]
                <0>ets Jun 8 2016 00:22:57
                rst:0x1 (POWERON_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff8028,len:8
                load:0x3fff8030,len:1688
                load:0x4009fa00,len:0
                load:0x4009fa00,len:14592
                entry 0x400a059c
                E (439) esp_image: Checksum failed. Calculated 0x1d read 0x67 # checksum error over here
                WMAC: 807D3AC263A8
                Firmware: 1.18.2
                Pybytes: 0.9.6
                  @eric-waai I tried twice in our office, my device got successfully updated from 1.18.2.r0 -> 1.18.2.r2
