    LTE driver appears to be stopped?
    lte-m1
    6 Posts 3 Posters 697 Views 4 Watching
    • R Offline
      Recurracy
      Hello everyone,
      I'm currently trying to connect to an LTE CAT M1 network.
      However, I'm seeing some things that I think aren't quite correct, and I'm not sure what to do.
      Here is the code I'm using to attempt to connect:
      from network import LTE
      lte = LTE()
      def pretty(cmd):
          print(cmd)
          response = lte.send_at_cmd(cmd).split('\r\n')
          for line in response:
              if line != '':
                  print(line)
      print("Test")
      pycom.rgbled(0xFF0000)
      if not lte.isattached():
          lte.attach()
          while (not lte.isattached()):
              print("Attaching to LTE... ")
              pretty('AT!="showphy"')
              time.sleep(5)
              pycom.rgbled(0x000000)
              pretty('AT!="fsm"')
              time.sleep(5)
      if not lte.isconnected():
          lte.connect()
          while not (lte.isconnected()):
              print("Connecting...")
      pycom.rgbled(0x00FF00)
      time.sleep(0.5)
      It doesn't even get past the attaching phase.
      This is the output of the FSM AT command:
      SYSTEM FSM
          |            FSM           |        STATE       |
          | RRC TOP FSM              |STOPPED             |
          | RRC SEARCH FSM           |NULL                |
          | RRC ACTIVE FSM           |NULL                |
          | PMM PLMN FSM             |NULL                |
          | EMM MAIN FSM             |NULL                |
          | EMM AUTH FSM             |NULL                |
          | EMM CONN FSM             |NULL                |
          | EMM TAU FSM              |NULL                |
          | EMM TEST FSM             |NULL                |
          | ESM BEARER FSM           |BEARER_NULL         |
          | SMS MT FSM               |IDLE                |
          | SMS MO FSM               |IDLE                |
          | HP MAIN FSM              |NULL                |
          | HP USIM FSM              |NULL                |
          | HP SMS MO FSM            |IDLE                |
          | HP SMS MT FSM            |IDLE                |
          | HP CAT FSM               |NULL                |
      Here is the output of the 'showphy' AT command:
      DL SYNCHRO STATISTICS
          Synchro state                         : OFF
          PPU SIB1 ACQ watchdog                 : 0
          Frequency Hypothesis RF  (Hz)         : 0
          RSRP (dBm)                            : 0.00
          RSRQ  (dB)                            : 0.00
          Channel estimation state (Cell-spec.) : LOW CINR
          Channel estimation state (UE-spec.)   : LOW CINR
          Channel estimation state (MBSFN)      : LOW CINR
          Channel estimation CINR               : 0.00
          Channel length                        : SHORT
        AGC
          AGC RX gain (dB)                      : 0.00
          RX PSD BO (dBFs)                      : 0.00
          RX PSD (dBm)                          : 0.00
          Noise level RS (dBm)                  : 0.00
          Digital gain (dB)                     : 0.00
          CINR RS (dB)                          : 0.00
        NARROWBANDS
          Last DL NB                            : 0
          Last UL NB                            : 0
        AFC
          Frequency offset RF  (Hz)             : 0
          Frequency offset BB  (Hz)             : 0
        PBCH
          MIB received quantity                 : 0
          MIB timeout quantity                  : 0
      OK
      I should note I have entered AT commands in the past before taking a simpler approach, such as "AT!=clearscanconfig". Is this command persistant after resetting the device?
      I've also updated the LTE driver as described in https://docs.pycom.io/tutorials/lte/firmware.html
        tlanier
        This example may help.
        import ssl
        import sys
        from utime import sleep_ms
        BLACK = 0x000000
        WHITE = 0xFFFFFF
        RED = 0xFF0000
        GREEN = 0x00FF00
        BLUE = 0x0000FF
        YELLOW = 0xFFFF00
        lte = None
        # send AT command to modem and return response as list
        def at(cmd):
            global lte
            print("modem command: {}".format(cmd))
            r = lte.send_at_cmd(cmd).split('\r\n')
            r = list(filter(None, r))
            print("response={}".format(r))
            return r
        # blink LED
        def blink(rgb, n):
            for i in range(n):
                pycom.rgbled(rgb)
                time.sleep(0.25)
                pycom.rgbled(BLACK)
                time.sleep(0.1)
        # run test
        def run():
            global lte
            print("GPy CAT M1 Test - V0.6 - 2/26/19")
            try:
                print("disable MicroPython control of LED")
                pycom.rgbled(WHITE)
                print("instantiate LTE object")
                lte = LTE()
                print("reset modem...")
                lte.reset()
                # resolves issue of iccid() not working after reset()
                LTE.reconnect_uart()
                lte.init()
                sleep_ms(1500)      # 750 works
                iccid = lte.iccid()
                carrier = iccid[0:5]
                print("iccid = {0}".format(iccid))
                imei = lte.imei()
                print("imei = {0}".format(imei))
                apnx = "10569.mcs"   # apn based on SIM card used
                lte.attach(apn=apnx)
                while not lte.isattached():
                    print("waiting for attach...")
                    blink(RED, 1)
                print("connect: start a data session and obtain an IP address")
                lte.connect()
                while not lte.isconnected():
                    print("waiting for connection...")
                    blink(GREEN, 1)
                print("connected!!!")
                pycom.rgbled(BLUE)
                print("read first 16 bytes of www.google.com site")
                s = socket.socket()
                # must be called only if connecting to secure site
                s = ssl.wrap_socket(s)
                print("get www.google.com address")
                addr = socket.getaddrinfo('www.google.com', 443)
                print(addr)
                print("connect to {}".format(addr[0][-1]))
                s.connect(addr[0][-1])
                print("GET 16 bytes from google")
                s.send(b"GET / HTTP/1.0\r\n\r\n")
                print(s.recv(16))   # receive 16 bytes
                print("close socket")
                s.close()
                lte.disconnect()
                pycom.rgbled(BLACK)
                print("end of test")
            except Exception as ex:
                sys.print_exception(ex)
        • R Offline
          Recurracy
          Sadly, that didn't seem to change anything. I'm not sure why, but the synchro state continues to be OFF, and all other values remain 0, as if nothing has been initialized:
              Synchro state                         : OFF
              RSRP (dBm)                            : 0.00
              RSRQ  (dB)                            : 0.00
            AGC
              RX PSD (dBm)                          : 0.00
              CINR RS (dB)                          : 0.00
            NARROWBANDS
              Last DL NB                            : 0
              Last UL NB                            : 0
            AFC
            PBCH
          OK
          Furthermore, 'AT+COPS=?' returns an ERROR. Which I find weird considering that I did upgrade the modem firmware. I'm not sure what is going on here.
            tlanier @Recurracy
            @recurracy
            Have you added an APN to the attach method call?
            • R Offline
              Recurracy
              I managed to get it working. Thank you for your responses, @tlanier.
              Is it true the RTS and CTS jumpers on the Pymakr board can make a difference in the modem functioning? I had connected them before, a colleague suggested taking them off.
              Here is the initialization code:
              print("init lte")
              lte.init()
              print("reset lte")
              lte.reset()
              pretty('AT^RESET')
              time.sleep(5)
              pretty('AT+CFUN=0')
              pretty('AT!="clearscanconfig"')
              pretty('AT!="addscanfreq band=20 dl-earfcn=6400"')
              pretty('AT+CGDCONT=1, "IP", "ltem.internet.m2m"')
              pretty('AT+CFUN=1')
              pretty('AT+CEREG?')
              pretty('AT+COPS=?')
              • R Offline
                rskoniec @Recurracy
                @recurracy If you mean Expansion board - yes, RTS and CTS jumpers must be removed for modem communication.
                https://docs.pycom.io/gettingstarted/connection/fipy.html
                When using the expansion board with a FiPy, you will need to remove the CTS and RTS jumpers as these interfere with communication with the cellular modem.
