    Firmware Release Candidate v1.20.0.rc8
    firmwarepymesh
    3 Posts 2 Posters 753 Views 2 Watching
    • I Offline
      iwahdan
      Re: New Firmware Release Candidate v1.20.0
      Hello Everyone ,
      we've uploaded new Firmware Release v1.20.0.rc8 as a candidate release for coming new stable release v1.20.0 this release include the following changes:
      New Features
      • Pymesh Border Router - docs updated and simple example
      Improvments
      • Added API to Enable/Disable Bluetooth modem Sleep
      • Merged IDF_V3.1 updates from Essprisif
      • Amended Micropython Error Codes with ESP, LWIP, MBEDTLS, DNS error codes
      • Updated Sqnsupgrade lib to v1.2.3
      • Pymesh updates:
        • added socket binding to IP, add listing border_router
        • solved issue: src and dest port on BR should he Host Swapped
        • Mesh.rx_cb() added argument, with the callback
        • added Mesh.border_router_del(prefix) method, for erasing Border Router entry
        • added multi-socckets (max 3)
        • added Border Router socket with header IP and port destination
      Bug Fixes
      • Fix Issue: Wifi not resuming after 2nd light sleep wakeup cycle
      • Fix Uart crash Issue when UART I/O functions are called after deinit
      You can download the sources from https://github.com/pycom/pycom-micropython-sigfox/tree/v1.20.0.rc8
      You also can flash Pycom boards with this release by choosing development type in Firmware updater tool
      <later edit:> Added Pymesh links and update summary.
      Wahdan
      • R Offline
        rfinkers
        Is there already some documentation for the Pymesh Border Router?
        • I Offline
          iwahdan @rfinkers
          @rfinkers the Pymesh Docs page is under that link : https://docs.pycom.io/firmwareapi/pycom/network/lora/pymesh.html , it will be updated shortly with the Border router documentation.
          Wahdan
