What is the WiPy 2.0 and LoPy CPU Clock Rate ?
 I am completing a MicroPython board spec comparison...
 started with Free RAM and internal ROM...
 but I've expanded it now :-()The Spec sheets for WiPy 2.0 and LoPy are very nice and complete...except for MCU Clock rate (MHz).
 WiPy 1.0 has...
 Processing
 ★Dual processor + WiFi radio SoC.
 ★MCU: Texas Instrument CC3200, Cortex-M4 @ 80MHz
 WiPy 2.0 and LoPy just have...
 Processing
 – Espressif ESP32 chipset
 – Dual processor and WiFi radio system on chipWhat are the MCU Clock rates for the WiPy 2.0 and LoPy ?
 Being more specific, MicroPython release 0.9.6.b1 for LoPy and WiPy 2 has default ESP32 frequency set as 160 MHz, instead of 80 MHz as before.
 @VitalSparkPlug, yes, both boards are ticking at 160MHz right now. Right now changing the clock requires a firmware rebuild, but this limitation might be lifted in the future.
 Thanks for the speedy reply.
 Might need to update the Spec Sheet (Frequency is a "Basic" spec :-) )
 Is that for Both WiPy 2.0 and LoPy ?
 Can the Max you mentioned be reached by firmware control of the PLL?
 @VitalSparkPlug, the max frequency is 240 MHz. Right now we're clocking it at 160MHz. Hope it helps ;)
