Simple Lopy to Lopy via WiFi
  • Hi, I have some trouble to connect my two lopy4 via WiFi.
    Here is receiver code:
    s = socket.socket()
    port = 80
    s.bind(('0.0.0.0',port))
    print("Bind")
    s.listen(5)
    print("Listen")
       pycom.rgbled(0xFFFFFF)  # Blue
       c, addr = s.accept()
       print('Connection from :', addr)
       pycom.rgbled(0x00FF00)  # Green
       data = c.recv(64)
       print(data)
       c.send(b'Hello')
    And this is sender code
    from network import WLAN
    #Si connette ad una rete con un certo ssid e una certa password
    ssid = "****"  #ssid of the other lopy
    password = "*****" #password of the other lopy
    pycom.rgbled(0xFF0000)  # Red led at start
    wlan = WLAN(mode=WLAN.STA)
    nets = wlan.scan()
    s = socket.socket()
    for net in nets:
        if net.ssid == ssid:
            print("Found network: " + net.ssid)
            wlan.connect(net.ssid, auth=(net.sec, password), timeout=5000)
            while not wlan.isconnected():
                machine.idle() # save energy
            if wlan.isconnected() == True:
                    print(wlan.ifconfig())
                        b = bytes("Hello",'utf-8')
                        s.sendall(b)   #send butes
                        pycom.rgbled(0xFFFF00)
                        buffer = s.recv(64) #receive bytes
                        print(buffer) #print bytes received
                    print("WLAN connection error")
    When the sender codes arrive at line "s.sendall(b)", it gives me OS ERROR: 128, but I don't understand why. Can anyone help me?
  • Thanks @crumble and @timh for your answers!
    I've changed my code, because I want to implement a WiFi Direct between my two Lopy4 ( so one act like AP, and the other like STA). I have changed my code as you advised me:
    Server Main
    import usocket as socket
    wlan = WLAN()  # get current object, without changing the mode
    if machine.reset_cause() != machine.SOFT_RESET:
        wlan.init(mode=WLAN.AP, ssid='Lopy-wlan', auth=(WLAN.WPA2,'www.pycom.io'), channel=10, antenna=WLAN.INT_ANT)
        myconfig = wlan.ifconfig()
        lst_myconfig = list(myconfig)
        lst_myconfig[0] = '192.168.0.20'
        myconfig = tuple(lst_myconfig)
        wlan.ifconfig(config=myconfig)
        print("Wlan configuration", myconfig)
    s = socket.socket()
    s.bind((lst_myconfig[0],2000))
    s.listen(5)
    c, addr = s.accept()     # Establish connection with client.
    print ('Got connection from', addr)
    c.send(b'Thank you for connecting')   # Send bytes
    c.close()
    Client Main
    ssid1 = "Lopy-wlan"
    password = "www.pycom.io"
    wlan = WLAN(mode=WLAN.STA) #station
    nets = wlan.scan()
    s  = socket.socket()  #create socket
    for net in nets:
        if net.ssid == ssid1:
            wlan.connect(net.ssid, auth=(net.sec, password), timeout=5000) #connected to lopy AP
    s.connect(socket.getaddrinfo('192.168.0.20',2000)[0][-1])
    s.sendall(b)   #send bytes
    s.close()
    I've upload Server code on my Lopy server, then I run Client code on my Lopy client, but when I try to connect the socket ( with s.connect(...)) I have OSError: -1.
    I've seached on google but I did not find anything.
    What can it be?
  • @p-m-97
    The socket is not connected. WiFi communication is point2point by default. So you have to provide a target adress and port.
    Set up an own network with fix IP numbers. This will be the easiest way to start. You can switch to broadcast, after you managed the p2p communication.
  • @p-m-97 Maybe you haven't supplied all of your code, but a few things stand out.
    In your sender code you don't actually connect to anything with the socket.
    Somewhere you need to call sock.connect(addr)
    In addition in your listener code, you don't connect to the wifi network and that should occur before you bind.
