    MQTTClient subscriptions not working
    2 Posts 1 Posters 243 Views 1 Watching
      cmisztur
      Just curious what I'm doing wrong here. LoPY4 1.19.0.b4
      I'm assuming this is the client code: https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/frozen/Common/MQTTClient.py
      I can publish but I cannot get a subscription working.
      The most I see is 'Packet sent. (Length: 4)' when publishing a message through broker when LoPY4 is subscribed.
      from MQTTClient import MQTTClient
      l99_serial = "abc"
      mqtt_client = MQTTClient(l99_serial, False, 4)
      mqtt_client.setLastWill('L99/{}/io/state/offline'.format(l99_serial), QoS=1)
      mqtt_client.configEndpoint('192.168.2.107', 1883)
      mqtt_client.connect(180)
      def mqtt_output_command_callback(ud,p=5):
          print('sub')
          print(ud)
      #mqtt_client.subscribe('L99/{}/io/OUTPUT/+/+'.format(l99_serial), 1, mqtt_output_command_callback)
      #mqtt_client.publish('L99/{}/io/state/online'.format(l99_serial), '', 1, False)
      mqtt_client.subscribe('L99/#', 1, mqtt_output_command_callback)
        cmisztur @cmisztur
        Well, whatever umqtt.simple works fine.
        from umqtt.simple import MQTTClient
        def mqtt_output_command_callback(topic,message):
            print('sub')
            print(topic)
        l99_serial = "abc"
        mqtt_client = MQTTClient(l99_serial, '192.168.2.107', 1883)
        mqtt_client.set_last_will('L99/{}/io/state/offline'.format(l99_serial), '', qos=1)
        mqtt_client.connect()
        mqtt_client.set_callback(mqtt_output_command_callback)
        mqtt_client.subscribe('L99/{}/io/OUTPUT/+/+'.format(l99_serial), qos=1)
        mqtt_client.publish('L99/{}/io/state/online'.format(l99_serial), '', qos=1)
            machine.idle()
            mqtt_client.check_msg()```
