    Firmware update elf vs tar
    14 Posts 4 Posters 1.4k Views 4 Watching
      jason_gladen
      How do I load firmware offline now from an elf file?
      I need to load firmware in the field where I don't have a reliable internet connection.
      It looks like the releases are provided in elf format
      the old version seems to be tar gziped
      it seem like the pycom-fwtool-cli and Pycom Firmware Updater (Flash from local file) are expecting a tar file
      Either I'm looking at the wrong link for the firmware https://github.com/pycom/pycom-micropython-sigfox/releases
      Or I don't know how wrap package the elf into tar.gz
      I unpacked an old copy of a tar of 1.20.rc7 and that doesn't seem to contain the 1.20.rc7 elf =?= bin (but sizes seem very different)
      I think i'm missing something really simple.
        robert-hh @jason_gladen
        @jason_gladen The tar-gz file contain the binary image, which is not identical to the elf file. You can install the tar files with the pycom updater, but the most recent versions are not available for download, which I consider an omission. And it was promised to provides also the up-to-date tar files! Ping, @Paul-Thornton
        Until then you could repack the tar file. The conversion of the .elf file into the .bin file is done with esptool.py. flashfreq=80Mhz, flashmode=dio. Once you have a bin file, you can grap an older tar file for your target, unpack it, replace the bin file, and re-pack it again. This new tar file can then be installed into your device.
        • rcolisteteR Offline
          rcolistete
          It's here, Pycom Docs - Firmware Downgrade.
            robert-hh @rcolistete
            @rcolistete You're right. Sorry Paul.
              andreas
              Hi there,
              yesterday, we tried to update to the newest 1.20.1.r1 firmware from the command line.
              Rebundling
              Following your suggestions (thanks again, @robert-hh!), we tried to use the tarball release from 1.20.0.rc13, convert the 1.20.1.r1 ELF file from the GitHub release page into a .bin file using esptool like:
              esptool.py --chip esp32 elf2image --flash_freq=80m --flash_mode=dio --output FiPy-1.20.1r1/fipy.bin FiPy-1.20.1.r1-application.elf
              and then wrap it into the tarball again.
              Flashing
              When trying to flash that guy, we firstly got the weird error message Invalid script command f (see https://forum.pycom.io/topic/3970/error-in-lopy-firmware-upgrade-when-using-local-file-for-both-cli-and-gui-linux) using the old Pycom Firmware Update tool.
              After upgrading to the latest version of the Pycom Firmware Update tool, we are receiving this message:
              $ pycom-fwtool-cli --verbose --port $MCU_PORT flash --tar FiPy-1.20.1r1.tar.gz
              Running in PIC mode
              Product ID: 152 HW Version: 7 FW Version: 0.0.11
              Connecting....
              Uploading stub...
              Running stub...
              Stub running...
              Changing baud rate to 921600
              Changed.
              Auto-detected Flash size: 8MB
              Error Loading script_8MB ... defaulting to legacy script2!
              Compressed 4 bytes to 12...
               Writing o at 0x0000000B... (100 %)
              Hash of data verified.
              Wrote 4 bytes (12 compressed) at 0x0000000b in 0.1 seconds (0.4 kbit/s)...
              Flash operation successful.
              Obviously, it still doesn't work, the FiPy would not start.
              Thoughts and aims
              So, we assume we are lacking the appropriate bootloader.bin and partitions.bin files, maybe we also need updated variants of the script and script2 files located within the tarfile.
              In this manner, we are humbly asking if someone of you could kindly provide us with these files from a current Dev build on their workstation to save us from running the build process on our own machines.
              We would like to upload a ready made tarball https://packages.hiveeyes.org/hiveeyes/foss/pycom/ in order to streamline the installation for the people within our community. This might actually help others, too.
              Thanks already and with kind regards,
              Andreas.
                robert-hh @andreas
                @andreas I get this spurious Invalid script command f too. On tepeati attempts of the flash it succeeds. I did not look into the code yet, but it seems to be some inconsistent error handling.
                Interestingly, the new firmware build package of Pycom generates the tarballs. The new images require to erase the flash beforehand.
                  robert-hh @robert-hh
                  @robert-hh I have two of these tarballs here: https://hidrive.ionos.com/share/eyz4etzbfv
                    andreas
                    Dear @robert-hh,
                    thanks for the quick response.
                    Flash success
                    I am able to confirm flashing these guys using the the new Pycom Firmware Update from the command line like
                    pycom-fwtool-cli --verbose --port $MCU_PORT flash --tar ~/Downloads/FiPy-1.20.1.r1.tar.gz
                    works excellent for me,
                    Pycom MiroPython 1.20.1.r1 [d4b4717] on 2019-10-12; FiPy with ESP32
                    so I uploaded them to [1]. Thanks a bunch!
                    Rebuild fail
                    However, even when trying to rebundle the tarfile using its original content, the flash process will insist on croaking like
                    when using the new tarfile. I haven't come across Invalid script command f since updating the Pycom Firmware Updater to the most recent version for macOS.
                    As I am working on macOS, I even resorted to the GNU tools provided by Homebrew in order to rule out anything from BSD Tar oder Apple Gzip, so I tried both commands [2] and [3] to no avail at all. Bummer!
                    Conclusion
                    As I am really feeling a bit silly on that, I am now asking myself whether there might be any magic sauce required when cooking these tarballs and wanted to share my observations with the community. Saying that, it might be obvious for someone what I am doing wrong.
                    Nevertheless, thank you so much again for providing the tarballs!
                    With kind regards,
                    Andreas.
                    [1] https://packages.hiveeyes.org/hiveeyes/foss/pycom/
                    [2] tar -czf FiPy-1.20.1r1.tar.gz --directory FiPy-1.20.1r1 .
                    [3] gtar -c --directory FiPy-1.20.1r1 . | /usr/local/bin/gzip -5 > FiPy-1.20.1r1.tar.gz
                      robert-hh @andreas
                      @andreas The archives which you create contain a directory (named .) and inside that the files of the package, whereas the tarballs created by Pycom 8and me) are flat. No subdirectory. Maybe that's the reason.
                        andreas
                        Thanks for your thoughts @robert-hh. I believed I also created a flat tarball without any subdirectories and when looking at them, they look good to me. After failing when trying to make my first tarball, I found that tar -c --directory FiPy-1.20.1r1 . should be the appropriate syntax for doing so.
                        If you see that I might be going into the wrong direction here, may I humbly ask how you are creating these tarballs in the appropriate format/style?
                        Thanks in advance!
                          robert-hh @andreas
                          @andreas If change into that directory with the files and issue the command:
                          tar cvfz ../FiPy-1.20.1r1.tar.gz *
                            andreas
                            Dear @robert-hh,
                            that works like a charm, thank you very much!
                            We are able to confirm this procedure works for us:
                            Get and extract vanilla tarball
                            # Download confirmed tarball release.
                            wget https://packages.hiveeyes.org/hiveeyes/foss/pycom/FiPy-1.20.1.r1.tar.gz
                            # Extract into temporary build directory.
                            mkdir build
                            tar -xzf FiPy-1.20.1.r1.tar.gz --directory build
                            Use Pycom firmware release
                            # Download most recent ELF file as of 2019-10-17.
                            http --download --follow https://github.com/pycom/pycom-micropython-sigfox/releases/download/v1.20.1.r1/FiPy-1.20.1.r1-application.elf
                            # Convert to image file and put into place.
                            esptool.py --chip esp32 elf2image --output build/fipy.bin FiPy-1.20.1.r1-application.elf
                            Create new tarball
                            cd build
                            tar -czf ../FiPy-1.20.1.r1-rebundled.tar.gz *
                            cd -
                            Flash to device
                            pycom-fwtool-cli --verbose --port $MCU_PORT flash --tar FiPy-1.20.1.r1-rebundled.tar.gz
                            Finally!
                            Thanks again and with kind regards,
                            Andreas.
                              andreas
                              Just for the records: Instead of identifying as
                              @andreas said in Firmware update elf vs tar:
                              Pycom MicroPython 1.20.1.r1 [d4b4717] on 2019-10-12; FiPy with ESP32
                              the firmware identifies itself as
                              Pycom MicroPython 1.20.1.r1 [v1.11-3138a13] on 2019-10-08; FiPy with ESP32
                              Pybytes Version: 1.1.3
                              after flashing the rebundled tarball using the most recent FiPy-1.20.1.r1-application.elf file from the GitHub release page.
                                andreas
