    ABP - troubleshooting first connection attempt
    1 Posts 1 Posters 195 Views 1 Watching
    • dwsD Offline
      dws
      I'm new to LoRA and am attempting to get a LoPy 4 to connect to a known working gateway. I'm running the ABP code from here: https://docs.pycom.io/tutorials/lora/lorawan-abp.html and I'm trying to figure out if it's actually working. It doesn't throw an error, it just ends after printing b''. In a attempt at troubleshooting I printed out the value returned by the join() function, and that is "None". The API does not specify what this function returns, if anything, so I don't know if None is conclusive.
      I see no data associated with my app / device in the TTN console.
      I am looking at everything and wondering what the '00000005' value is in this line, I'm assuming this should be the Device Address from the TTN console:
      dev_addr = struct.unpack(">l", ubinascii.unhexlify('00000005'))[0]
      This is not documented in the API from what I can tell.
      Bottom line is, how do I know when I've joined a gateway if the gateway returns no data, i.e if socket.recv() returns no data?
      thanks
