urequest.py
  • hello pycom ,i want need the urequest.py update of pycom the older one of github is update?because i try to make post with json data but it crash with no response. then i need to know if someone use it or have changed some instructions .thank you
  • There are many github deposit for urequest.
    I don't know if you noticed that some librarie are for urequest and some for urequests
    The last librairie I founded at this time for urequests was in the micro-python's deposit you can found here : https://github.com/micropython/micropython-lib
    You can use it as simply as :
    import urequests
    req = urequests.get("http://<your.personal.url>/",
                                    {"param1":"value1",
                                     "param2":"value2"} )
