adaptive coding rate
Hi I would like to implement an algorithm which adaptively supplies the coding rate values from 1 to 4 as it senses the lowering of data rates. Is this possible just by feeding in the SNR values (RSSI). I guess that based on the snr values dropping down over distance we can incorporate the next higher coding rate possible.
Will this approach be fine?
Your feedback is appreciated.
