    New release New firmware release 1.2.2.b1
    36 Posts 10 Posters 13.4k Views 10 Watching
      daniel
      Hello everyone,
      Here we are with an early week release that improves the interrupt functionality and fixes some bugs that were present in the previous release. These are the release notes:
      • When a thread dies remove it from the linked list. Also release the memory it had allocated. Fixes #39 (https://github.com/pycom/pycom-micropython/issues/39)
      • Kill the interrupts tasks during a soft reset.
      • Enable the finalizer for Alarms.
      • Release the GIL before blocking
      • Test for possible handler=None in queued callbacks.
      • Move functions called by ISRs to RAM to fix gurus on Alarms and Pins.
      • Pass the correct stack size when creating threads.
      • Correct pins P13 and P14 that were inverted.
      As usual, the new firmware can be flashed using the updater tool found in: https://www.pycom.io/support/supportdownloads/
      Cheers,
      Daniel
      F 1 Reply Last reply Reply Quote 1
        jmarcelino
        Oh this is a very welcome early bug fix release.
        I was trying some periodic Alarm code which was crashing with a Guru Meditation error at about every 142 events on the previous beta. Happy to report that's now running well into the thousands and still ticking away nicely.
        This even before I even had a proper chance to report it! Amazing :-)
        • bmarkusB Offline
          bmarkus
          How much free RAM is available?
            jmarcelino @bmarkus
            @bmarkus
            >>> import gc
            >>> gc.mem_free()
            42464
            bmarkusB 1 Reply Last reply Reply Quote 0
            • bmarkusB Offline
              bmarkus @jmarcelino
              @jmarcelino said in New release New firmware release 1.2.2.b1:
              @bmarkus
              >>> import gc
              >>> gc.mem_free()
              42464
              Thanks, getting better.
                robert-hh
                As a hint for everyone who is building the image her- or himself:
                Please update the pycom-esp-idf too. Otherwise the build will not run.
                  jmarcelino
                  OK first let me say the new release is a massive improvement, before this same code would crash after only 140 or so Alarm events. However it's still crashing without fail in the 2500-3000 range.
                  Note I may well be doing something wrong as I just started with MicroPython this Xmas!
                  First the crash:
                  [...some output here]
                  Elapsed 2690 s
                  Hourly average 22.84 mAh
                  Consumed 17.07
                  Elapsed 2691 s
                  Hourly average 22.83 mAh
                  Consumed 17.07
                  Elapsed 2692 s
                  Hourly average 22.82 mAh
                  Guru Meditation Error of type InstrFetchProhibited occurred on core  0. Exception was unhandled.
                  Register dump:
                  PC      : 0x00692cc0  PS      : 0x00060430  A0      : 0x800ecdd4  A1      : 0x3ffc4bb0
                  A2      : 0x3ffc5490  A3      : 0x00000001  A4      : 0x00000000  A5      : 0x3ffc4bd0
                  A6      : 0x400dc2cc  A7      : 0x3ffc1340  A8      : 0x800ecd90  A9      : 0x3ffc4b90
                  A10     : 0x3ffc5490  A11     : 0x00000001  A12     : 0x00000000  A13     : 0x3ffc4bd0
                  A14     : 0xb33fffff  A15     : 0x3ffc4b70  SAR     : 0x0000001c  EXCCAUSE: 0x00000014
                  EXCVADDR: 0x00692cc0  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
                  Backtrace: 0x00692cc0:0x3ffc4bb0 0x400ecdd4:0x3ffc4bd0 0x400dc2dc:0x3ffc4c00 0x400e0e3e:0x3ffc4c20 0x400d81d8:0x3ffc4ca0
                  Rebooting...
                  and my code (shortened version I'm using for testing)
                  from machine import Pin
                  from machine import Timer
                  import micropython
                  micropython.alloc_emergency_exception_buf(100)
                  class LTC4150(object):
                      ah_quanta = 0.17067759
                      def __init__(self):
                          self.p_in = Pin('P15', mode=Pin.IN, pull=None)
                          self.p_in.callback(Pin.IRQ_FALLING, self.__pin_handler)
                          self.chrono = Timer.Chrono()
                          self.chrono.start()
                          self.count = 0
                          self.time = 0
                          self.lastTime = 0
                      def __pin_handler(self, arg):
                          self.count = self.count + 1
                  def periodic_handler(alarm):
                      mA = cc.count* cc.ah_quanta
                      seconds = cc.chrono.read()
                      print("Consumed %.2f" % mA )
                      print ("Elapsed %d s " % seconds)
                      print("Hourly average %.2f mAh" % ((3600*mA)/seconds))
                  cc = LTC4150()
                  alarm = Timer.Alarm(periodic_handler, 1, periodic=True)
                  If I increase the period say to 10s it still crashes just takes 10x as long, so I think it's more to do with the number of events
                  Thanks for the help
                    daniel
                    @jmarcelino thanks for the report, we are investigating why those crashes are occurring. We'll let you know once we discover the root cause.
                    Cheers,
                    Daniel
                      pdp8user
                      Do we have to call the finalizer explicitly, or is it automatic?
                      • M Offline
                        mohpor
                        @daniel
                        Wonderful update I gotta admit. Fixed a lot of memory problems! One problem that has been fixed and I haven't see anybody reporting was that you could run your code 2 times and then it would crash on the 3rd try. It is now fixed and I can upload my code as many time as I want to! Fantastic.
                        Cheers,
                        M.
                          daniel @mohpor
                          @mohpor cool :-) thanks for the feedback!
                          Cheers,
                          Daniel
                            daniel @pdp8user
                            @pdp8user it's automatic.
                              pdp8user @daniel
                              @daniel Thanks for that and the prompt reply.
                              Keep up the good work! The memory issues have been frustrating, because as @mohpor says, something would work some times and not others.
                              I'm still having some issues in that respect, which is why the question about the finalizer. I've still to clarify the details, then I'll report it to you.
                              Cheers,
                              Brian
                                daniel @pdp8user
                                @pdp8user thanks. Yes, please let us know the details about the issues that you are experiencing so that we can analyze the problem.
                                • bmarkusB Offline
                                  bmarkus
                                  On the download page current firmware version is 1.2.0.b1 see
                                    livius @bmarkus
                                    @bmarkus
                                    this is only not updated web page label
                                    updater tool update to version expected 1.2.2.b1
                                    • M Offline
                                      mohpor
                                      @daniel
                                      Hi again,
                                      Are we still up for today's update? (despite of the early 1.2.2.b1 update)
                                        daniel @mohpor
                                        @mohpor the release is going to be out tomorrow (Friday 13), we still need one more day to complete all the features that we are targeting for this next release. Apologies for the delay...
                                        Cheers,
                                        Daniel
                                          livius @daniel
                                          @daniel
                                          sorry for spam but good date "Friday 13" :)
                                            daniel @livius
                                            @livius haha :-)
                                            • 1
                                            • 2
                                            • 2 / 2
