    GPy - NB-IoT (Vodafone - Germany), didn't get it working
    1 Posts 1 Posters 280 Views 2 Watching
    • B Offline
      BlackDuck
      i try to get my GPy working with Vodafone NB-IoT working but i am stuck and i am unsure where is the problem.
      With help of robert-hh i got some steps forward but i did get it attached, and the documention do not help
      me.
      First a bit over my equipment
      1 x Vodafone NB-IoT datacard
      1 x 1nce - 1nce.de NB-IoT which is a Reseller for German Telekom
      1 x PyTrack 1.1
      1 x Expansion Board 3.1
      2 x GPy's one with limited Band support the other looks like this
      lte.send_at_cmd('AT!="RRC:showcaps"')
      == CAPS config =============================
        .Lock UE on SRV band    : false
        .MFBI support           : true
        .TM8 TDD support        : false
      == CAPS ====================================
        . access stratum: R13
        . catM          : 1
        . nb-IoT        : 1
      -- EUTRA bands --
        . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
        . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
        . admin         :
        . pending admin :
      -- EUTRA carriers --
        . admin         :
        . pending admin :
      I tried a lot but i didn't get it attached. If found this link https://forum.pycom.io/topic/4240/t-mobile-nb-iot-in-the-netherlands-solved/2 with a great diagnostic script.
      Sysname: GPy
      Release: 1.20.0.rc8
      Version: v1.9.4-7b83c6d on 2019-03-06
      Machine: GPy with ESP32
      Query LTE modem imei... 35434**********
      Query SIM iccid... 89492***************
      Sent to modem: 'ATI1', delay 1000 ms
      UE6.0.0.0
      LR6.0.0.0-40343
      OK
      Sent to modem: 'AT!="showver"', delay 1000 ms
      SYSTEM VERSION
        FIRMWARE VERSION
          Bootloader0  : 5.1.1.0 [41065]
          Bootloader1* : 6.0.0.0 [40343]
          Bootloader2  : 5.1.1.0 [41065]
          NV Info      : 1.1,0,0
          Software     : 6.0.0.0 [40343] by robot-soft at 2018-11-07 13:57:00
          UE           : 6.0.0.0
        COMPONENTS
          ZSP0         : 1.0.99-3171
          ZSP1         : 1.0.98-3170
      OK
      Sent to modem: 'AT+SQNCTM?', delay 1000 ms
      +SQNCTM: standard
      OK
      LTE attaching...
      Attaching... 1
      Attaching... 2
      Attaching... 3
      Attaching... 4
      Attaching... 5
      Sent to modem: 'AT+SQNMONI=9', delay 1000 ms
      ERROR
      Sent to modem: 'AT+CEREG?', delay 1000 ms
      +CEREG: 2,2
      OK
      Sent to modem: 'AT+CFUN?', delay 1000 ms
      +CFUN: 1
      OK
      Sent to modem: 'AT+CSQ', delay 1000 ms
      CSQ: 29,99
      OK
      Sent to modem: 'AT!="showphy"', delay 1000 ms
      DL SYNCHRO STATISTICS
          Synchro state                         : FAST SCAN
          PPU SIB1 ACQ watchdog                 : 0
          Frequency Hypothesis RF  (Hz)         : 0
          RSRP (dBm)                            : -21474836.00
          RSRQ  (dB)                            : -13.37
          Channel estimation state (Cell-spec.) : HIGH CINR
          Channel estimation state (UE-spec.)   : LOW CINR
          Channel estimation state (MBSFN)      : LOW CINR
          Channel estimation CINR               : 3.42
          Channel length                        : SHORT
        AGC
          AGC RX gain (dB)                      : 38.61
          RX PSD BO (dBFs)                      : -15.13
          RX PSD (dBm)                          : -75.57
          Noise level RS (dBm)                  : -115.18
          Digital gain (dB)                     : 0.37
          CINR RS (dB)                          : 40.00
        NARROWBANDS
          Last DL NB                            : Central
          Last UL NB                            : 0
        AFC
          Frequency offset RF  (Hz)             : 0
          Frequency offset BB  (Hz)             : 0
        PBCH
          MIB received quantity                 : 0
          MIB timeout quantity                  : 0
      OK
      Sent to modem: 'AT!="fsm"', delay 1000 ms
      SYSTEM FSM
          |            FSM           |        STATE       |
          | RRC TOP FSM              |SCANNING            |
          | RRC SEARCH FSM           |WAIT_RSSI           |
          | RRC ACTIVE FSM           |NULL                |
          | PMM PLMN FSM             |NORM_WAITCELL       |
          | EMM MAIN FSM             |NULL                |
          | EMM AUTH FSM             |NULL                |
          | EMM CONN FSM             |NULL                |
          | EMM TAU FSM              |NULL                |
          | EMM TEST FSM             |NULL                |
          | ESM BEARER FSM           |BEARER_NULL         |
          | SMS MT FSM               |IDLE                |
          | SMS MO FSM               |IDLE                |
          | LPP FSM                  |IDLE                |
          | HP MAIN FSM              |IDLE                |
          | HP USIM FSM              |READY               |
          | HP SMS MO FSM            |IDLE                |
          | HP SMS MT FSM            |IDLE                |
          | HP CAT FSM               |IDLE                |
      OK
      Maybe someone can see here the problem. This attempt above is with the Vodafone datacard.
      Kind Regards
      Marc
