    Layout documetation, SiPy vs PySense, what is correct
    6 Posts 2 Posters 286 Views 2 Watching
      PeterB
      If you compare:
      https://docs.pycom.io/.gitbook/assets/sipy-pinout.pdf
      https://docs.pycom.io/.gitbook/assets/pysense-pinout.pdf
      The naming of the pins do not match, especially the GPIO numbering.
      What is correct?
        robert-hh @PeterB
        @PeterB The Pysense sheet seems to be completely wrong. The Pinout is that of the old WiPy1.
          PeterB @robert-hh
          @robert-hh OK, Thanks. I hope you only mean the GPIO naming mentioned on the PySense doc?
          Or are there others which are also wrong?
            robert-hh @PeterB
            @PeterB The GPIO numbers are wrong. Reset, GND, 5V and 3V3 are correct. The functional labels should be fine too.
              PeterB
              Now I see, the documentation the page, especially the layout of:
              https://docs.pycom.io/datasheets/boards/pysense.html
              is different from what is shown in the pdf referenced on that page:
              A pdf is easier to print, so used that one but now found out it is out-of-date.
              Why is it not updated ???
                robert-hh @PeterB
                @PeterB Actually it should read Gxx instead of GPIOxx, where not by chance that matches the old WiPy1 numbers. And yes, this inconsistency has been reported over & over. It should have been fixed.
