    Interference of functions? Pin Wake Up, I2C, SD-Card
    1 Posts 1 Posters 149 Views 1 Watching
      PeterB
      I have a SiPy and a Pysense, on one set the program works fine on another with exactly the same programs etc it does not work. I suspecting some interference between functions which on some device combinations is more critical than on others
      Ref:
      https://docs.pycom.io/.gitbook/assets/sipy-pinout.pdf
      https://docs.pycom.io/.gitbook/assets/pysense-pinout.pdf
      I have on IO header pin 6, as dfined by the pysense library, a wake-up button (connected to 3v3_PyModule and a resistor of 1k5 to ground)
      That pin 6 of the IO header is connected to P9 of the SiPy. But that seems to be used for sdDATA2 and an SDA.
      • Would that give interference with the SD card of the PySense?
      • Would that give some interference with some I2C I do not know of. (SDA/SCL for PySense are on P21/P22)
      I defined P10 as SDA and P11 as SCL for I2C to an external RTC (the internal RTC does not hold its time when sleeping)
      • But P10 is also marked in the diagram as SCL for some unknown I2C. Would that give some interference?
