    L01 Power regulator?
    l01oem3v3powerregulator
    2 Posts 2 Posters 274 Views 2 Watching
    • R Offline
      rfinkers
      In the L01 datasheet there is this text block:
      "The L01 features an on–board voltage regulator that takes 3.5V – 5.5V from the VIN pin and regulates it to 3.3V. It is important to only use the 3.3V as an output and not try to feed 3.3V into this pin as this could damage the regulator."
      I think this is an copy/paste mistake... ?
      • M Offline
        Martinnn
        https://docs.pycom.io/.gitbook/assets/l01-pinout.pdf says:
        3V3 pin: Supply with a stable 3V3 power source capable of delivering at least 650mA
