    LoPy4 locking on sending and receiving data
    lopy4sigfoxlocking
    8 Posts 2 Posters 701 Views 2 Watching
      Track
      In my project I need an a downlink communication to my LoPy4. I set blocking to True and enable downlink and send a one bit message with the socket 's' in the following way:
      # init Sigfox for RCZ1 (Europe)
      sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
      # create a Sigfox socket
      # make the socket blocking
      s.setblocking(True)
      # configure it as DOWNLINK specified by 'True'
      s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, True)
      # send 1-bit message
      s.send("")
      Thus far I have followed all the examples and tutorials I can find online, this results in the simple code above. However, if I run the code I get an "OSError: [Errno 100] ENETDOWN" error. I solved this by catching it and continueing on to a receive statement.
      Sadly the follwing code does not work either:
      try:
          s.send("")
      except OSError:
          # handle possible things
          pass
      s.recv(64)
      While the code now moves past the sending of data, it locks on the receiving. It does not receive anything, while the backend shows proper handeling of te callback.
      Could someone help in pointing out what I am missing or am missunderstanding.
      Thanks in advance!
      edit: added the Sigfox object initialisation after the comment of @Eric73
      • E Offline
        Eric73
        It seem you are missing one init in your code (init sigfox stack), i show you the (simplified) code i use
        from network import Sigfox
        UplinkFrame=''
        Sfx=Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
        SfxSoc = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
        SfxSoc.setblocking(True)
        SfxSoc.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, True)
        ret=SfxSoc.send(bytes(UplinkFrame))
        Resp=SfxSoc.recv(32)
        print ("Sigfox RX:"+str(Resp))
          Track @Eric73
          @Eric73 Hi! Thank you so much for your comment! Sadly, I missed out on this in my description, but not in my code... I indeed initialise the Sigfox object before creating the socket. Do you happen to have any other idea? Does it lock for you as well?
          I am thinking that it might be my signal strength not being able to create a downlink message. However, I am grasping at straws.
          • E Offline
            Eric73 @Track
            @Track Hi Track, When you login to your sigfox backend did you see your uplink frame ? (it's the first step to have a downlink that the uplink is receive)
            How have you defined your "bidir" downlink in sigfox backend, as custom http callback ? aws service ? fixed data?...?
            What the backend (message tab- LQI) said about your link quality ? (good average low?)
            When you click on the arrow down in callback colomn what it indicate (for me " Status : [ACKED] Data (Hexa) : 000b36a45c000000" a red down arrow indicate a fail to send the downlink
              Track
              Hi @Eric73, thanks for the effort I have included all relevant information taken from my Sigfox account
              Bidirectional Callback Definition
              The HTTP Post which I receive on my own server and respond with the following JsonResponse (taken from django.http):
                  {trackerID}: {
                      "downlinkData": "1234567890123456"
              The status of the callback seems fine to me, except for the aforementioned signal strength:
              Where the status of the downlink looks like the following:
              As stated in my original message I would not know anything except for link quality. However, I still find it really strange that my LoPy4 lock when it tries to send data and need the try-catch: structure.
              Maybe you have even more helpful insight or spot the error in my ways here. Thanks again for the help!
                Track
                @Eric73 Hi, I just received the uplink twice successfully on the LoPy! I am now thinking that it might have worked yesterday as well, but before I had inserted a print statement my four messages a day were already used.
                However, this does introduce the new problem of locking out the LoPy if it does not receive a message. I suspect it has trouble sending the message over the low-quality connection. After that, it throws the Network Error. This belief is fortified by the successful output printing what has been sent:
                    print("send 1-bit message to the Sigfox cloud") # prints succesfully in both cases
                    try:
                        print(s.send("")) # prints '0' only when the downlink works
                    except OSError:
                        pass
                    print("wait to receive a message") # prints successfully in both cases, get stuck on this line if downlink does not work.
                    data = s.recv(64)
                    print(data) # prints "b'\x124Vx\x90\x124V'" (the correct payload as send by my server) if the downlink works. Otherwise this code is not reached at all.
                So the output if the downlink works is:
                0
                While the output if the downlink does not work is:
                If I do not receive a downlink I just want to continue on in the program (deep sleep and push information 5 hours later again). If I do receive a downlink I want the LoPy to do some extra work.
                I am curious to find out what you think.
                • E Offline
                  Eric73 @Track
                  @Track So, sigfox send message procedure cannot fail if hardware work (it's a loop of sending bit in dpbsk) BUT after sending it if you have set downlink to 1 (with SfxSoc.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, True) ) cpu wait 20 sec and then wait 25 sec on RX FSK 600bds for a downlink message.
                  All this work is done on one ESP32 core and the other run your application.
                  If there's no downlink receive you get ENETDOWN exception and when you do the s.recv(64) you go in infinite loop as the socket as been set in blocking (by s.setblocking(True) ) and no data will be never available.
                  Change your code to
                  RxDone=False
                  try:
                      s.send("")
                      s.recv(64)
                      RxDone=True
                  except OSError:
                      pass
                  if(RxDone==True):
                      DoYourStuffHere
                      Sleep6Hours
                  may solve your trouble
                    Track
                    @Eric73, thank you very much. Everything is functioning properly now!
