    Differences in GPS behaviour
    pytrack gps fai
    7 Posts 3 Posters 402 Views 3 Watching
      aliubi
      I just got two PyTracks and two WiPy4s, one set seems to work fine broadcasting its location once per second. The other set, running the same code, never seems to get a GPS fix, even though it seems to wait about 30 seconds each time. It seems like a hardware problem, but I wanted to see if anyone had any insight or experience with it before I sent the bad set back.
        jcaron @aliubi
        @aliubi can you share details about your code and the firmware versions in use?
        Note that the GPS chip supports both GPS and GLONASS satellites but some libraries will only handle one or the other, so if for some reason the chip locks onto the one not supported you may not receive updates.
          aliubi @jcaron
          @jcaron That particular problem somehow fixed itself over lunch the same day, now I'm chasing down something completely different...it resets unceremoniously when it gets a LoRa packet, but so far it seems it's not in the LoRa RX code, but later when I try to parse it (although this section is executed unconditionally). As far as I can tell, there's a "break" statement in my exception trapping that it's taking way, way too literally. Will post when I find out more.
            aliubi @aliubi
            Okay, looks like I'm close on the break statement...here's the code, with diagnostic print statements.
            import math
            import network
            from network import LoRa
            import os
            import utime
            import gc
            import ujson
            from machine import RTC
            from machine import SD
            from L76GLNSV4 import L76GNSS
            #from L76GNSS import L76GNSS
            from pytrack import Pytrack
            time.sleep(2)
            gc.enable()
            pycom.rgbled(0x0f0300)
            rtc = machine.RTC()
            py = Pytrack()
            l76 = L76GNSS(py, timeout=30)
            #print("Trying GPS time")
            gpsTime = l76.getUTCDateTimeTuple()
            #print("Waiting for GPS time")
            while gpsTime == None:
            #print("Refining GPS time")
            #print("Setting GPS time")
            rtc.init(gpsTime)
            #print(l76.getUTCDateTimeTuple())
            pycom.rgbled(0x00000f)
            lora = LoRa(mode=LoRa.LORA, region=LoRa.US915)
            #lora = LoRa(mode=LoRa.LORA,region=LoRa.US915,frequency=915000000,tx_power=20,bandwidth=LoRa.BW_500KHZ,sf=12,preamble=8,coding_rate=LoRa.CODING_4_8,power_mode=LoRa.ALWAYS_ON, tx_iq=False, rx_iq=False, adr=False, public=True, tx_retries=1)
            #print('LoRa active')
            # create a raw LoRa socket
            #print('Socket set')
            locLoc = {}
            remLoc = {'a': 0, 'o': 0}
            s.settimeout(1)
            #print('Timeout set')
            while (True):
                # Get our location
                coord = l76.coordinates()
                #print('Got coords')
                # send to other unit
                locLoc["a"] = coord[0]
                locLoc["o"] = coord[1]
                if type(locLoc["a"]) != 'float':
                    #coord1 = (0,0)
                    locLoc = {'a': 0, 'o': 0}
                enc = ujson.dumps(locLoc)
                gc.collect()
                #print(enc)
                s.setblocking(True)
                #print('Ready to send')
                pycom.rgbled(0x0f0000)
                s.send(enc)
                pycom.rgbled(0x000000)
                #print('Location sent')
                # See if we get an answer
                s.setblocking(False)
                #print('Blocking off')
                pycom.rgbled(0x000f00)
                print('LED green')
                coord2 = s.recv(64)
                print('Stats coming...')
                lora.stats()
                print('Message received: {}'.format(coord2))
                try:
                    print("Trying to decode")
                    remLoc = ujson.loads(coord2)
                    print("Restoring to tuple")
                    coord2 = (remLoc["a"],remLoc["o"])
                    if type(remLoc["a"]) != 'float':
                    print("Success, I think...")
                    break
                except ValueError:
                print('Message processed')
                print("{} - {} - {}".format(coord, coord2, math.atan2((locLoc["o"]-remLoc["o"])*math.cos(locLoc["a"]),remLoc["a"]-locLoc["a"])*180/3.1415926535))
            And the result:
            LED green
            Stats coming...
            Message received: b''
            Trying to decode
            Message processed
            (42.10828, -88.28986) - b'' - 0.0
            LED green
            Stats coming...
            Trying to decode
            Message processed
            (42.10836, -88.28994) - b'' - 0.0
            LED green
            Stats coming...
            Trying to decode
            Message processed
            (42.10838, -88.28993) - b'' - 0.0
            LED green
            Stats coming...
            Trying to decode
            Message processed
            (42.10838, -88.28994) - b'' - 0.0
            LED green
            Stats coming...
            Trying to decode
            Message processed
            (42.10839, -88.28994) - b'' - 0.0
            LED green
            Stats coming...
            Trying to decode
            Message processed
            LED green
            Stats coming...
            Message received: b'{"a": 0, "o": 0}'
            Trying to decode
            Restoring to tuple
            Success, I think...
            Pycom MicroPython 1.18.2.r3 [v1.8.6-849-a1641ca] on 2019-02-28; LoPy4 with ESP32
            The successful iterations are when it was the only kid on the LoRa block. The crash occurs when I activate the other module, which is running identical code. I guess I'm doing something so outrageous it can't even dignify it with an error message, but the only logical statement between the last print and the crash is "break." Again, I'm new to Python in general as well as to PyCom, so forgive me if it's obvious to everyone else.
            J C 2 Replies Last reply Reply Quote 0
              jcaron @aliubi
              @aliubi you probably want to post a new question as this is quite unrelated to the original issue and title...
                crumble @aliubi
                @aliubi
                or someone else sends something. LoRa is like a CB radio. You receive every message which someone sends over your channel. ou have to find a way how you can identifiy your plain LoRa messages or connect to a network which will do this for you.
                  aliubi @crumble
                  @crumble True, but it shouldn't reboot to the command prompt no matter what the source of the message, should it? @jcaron You're right, I'll post it in a separate thread.
