Regular Expresion - REPL - Guru Meditation Error
Hi Team,
I was trying to execute a RegEx using REPL in PyMakr and got the Meditation ErrorEnv : (sysname='LoPy', nodename='LoPy', release='1.2.2.b1', version='v1.8.6-317-g9ab243e on 2017-01-10', machine='LoPy with ESP32')>>> import ure >>> ure.match(b'^INFO( )+(.+)$','INFO {"server_id":"1ec445b504f4edfb4cf7927c707dd717","version":"0.6.6","go":"go1.4.2","host":"0.0.0.0","port":4222,"auth_required":false,"ssl_required":false,"max_payload":1048576}').group(0) Guru Meditation Error of type StoreProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x4008832d PS : 0x00060031 A0 : 0x80086fff A1 : 0x3ffc0790 A2 : 0x3ffc5105 A3 : 0x3ffec2e0 A4 : 0x00000001 A5 : 0x3ffec250 A6 : 0x000000aa A7 : 0x3ffec200 A8 : 0x25000000 A9 : 0x00000000 A10 : 0x0a000000 A11 : 0x00060023 A12 : 0x00060021 A13 : 0xb33f0000 A14 : 0xb33fffff A15 : 0x3ffec1e0 SAR : 0x00000020 EXCCAUSE: 0x0000001d EXCVADDR: 0x00000008 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0x00000000 Backtrace: 0x4008832d:0x3ffc0790 0x40086fff:0x3ffc07b0 0x4008591e:0x3ffc07d0 0x40087d90:0x3ffc07f0 0x400812dd:0x3ffc0800 Rebooting... ets Jun 8 2016 00:22:57 rst:0x3 (SW_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0x00 clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:QIO, clock div:2 load:0x3fff9010,len:8 load:0x3fff9018,len:248 load:0x40078000,len:4072 load:0x4009f000,len:940 entry 0x4009f1ecThanks & regards,
Hari
@pod32, this was just a minimalistic example that triggers the guru. Unfortunately, we've been busy dealing with other parts of the firmware, and unable to find the root cause of this bug.
Have you tried to replace it by something like "\s{30}"?
@robert-hh @abilio When can we expect a fix for this issue ?
A similar error was discussed in the original Micropython community here:
https://github.com/micropython/micropython/issues/2451
The problem is not solved yet, as far as I know.
@mkharibalaji, I narrowed it down to this test:
The next example will make it break:
import ure ure.match(b'^( )+$',' ') # this will breakBut this won't: (I just removed a whitespace)
import ure ure.match(b'^( )+$',' ')It seems it has something to do with the length of the parameter.
Thank you very much for you're report. We'll be looking into it.
