How LoPy and Raspberry Pi 3 work together?
Hi!
I am currently looking to build a LoRa/Wi-Fi/Bluetooth network with a Raspberry Pi 3 and the LoPy look like it have everything i need!
I only wanted to know if you can use the 3 technologies at the same time. For example, if i have a sensor that is far away i would like to use LoRa and if i have a sensor that is close i would like to use Wi-Fi or Bluetooth to collect the data.
So basically, i would have X sensors using different protocols and one receiver (The RPi) receiving in different protocol before sending the data to a database.
Is that possible?
Thank you!
The Pi3 has problems to use the UART and on board WiFi at the same time. If you need them both, disable the on board WiFi and use a stick
