    Mesh setup
    1 Posts 1 Posters 151 Views 1 Watching
    • R Offline
      rudivd
      Hi all,
      Working to get a demonstrator for mesh, got stuff working with the mesh github code and the 1.20.0.rc7 firmware (higher firmwares did hot work). Now I run into an issue that it is pretty difficult with a std. antenna to demonstrate the mesh, as all nodes see each other on short distance. Is there a way to (by software) to reduce RF output, so I can have the mesh routing to demonstrateably work ??
      I do not want to remove the antenna, as this might damage the LoRa chip on the LoPy4 ...
      Rudi
