Set lopy wifi ip when as access point
Hi, i search to change the ip adress of the lopy when he act as access point.
I use this code:
def Wifi_Init(): from network import WLAN wlan = WLAN(mode=WLAN.AP, ssid="Own SSID", auth=(WLAN.WPA2, 'Own password'), channel=11, antenna=WLAN.INT_ANT) wlan.ifconfig(config=('192.168.0.4', '255.255.255.0', '192.168.0.1', '8.8.8.8'))It's seems not what i want to do. Because a client a such config lopy, have '192.168.4.2' and can ping '192.168.4.1'.
Was it possible to set the ip of the access point, and the wifi client too?
@thibault it should be possible to change the AP IP address. We'll investigate it. Thanks.
Hi there,
according to this doc https://docs.pycom.io/pycom_esp32/library/network.WLAN.html you should pass id=1 when changing IP in AP mode.
Didn't test it though...Kind regards
@daniel Has this been implemented? I'm on a LoPy4 and am under the impression that in wlan.ap mode the device can only be addressed via 192.168.4.1.
