    Pygate incompatible with FiPy?
    pygategpyfipy
    6 Posts 4 Posters 419 Views 4 Watching
      jetatomic
      Important Note: Pygate is not compatible with FiPy.
      Source: pycom.io
      Would anyone be willing to explain the reasons for this limitation? Is the incompatibility permanent, or might it change with later versions?
      My gateway location at the edge of cellular coverage, but no wired internet or WiFi service is available.
        jetatomic
        I forgot to mention that I know, as the video below discusses, that the Gpy + Pygate would enable a cellular backhaul. However, with no LoRa on the Gpy, there's no parsimonious path to LoRaWAN (LoRa gateway) with a cellular backhaul.
        https://youtu.be/o5AXPHFiIqQ
          jetatomic
          It may be the case that I misunderstood the functionality of the Pygate. It looks like there's LoRa on the Pygate via the Semtech SX1257. If that's true, then my use-case would be resolved with GPy + Pygate.
          Can someone confirm that my original question had a flawed premise, and that GPy + Pygate would provide LoRaWAN gateway with cellular backhaul?
          F 1 Reply Last reply Reply Quote 0
            Clemens
            Would be interested also why the combination FiPy + PyGate is not possible.
              The Pygate is indeed incompatible with the Fipy, as the Fipy has both a LoRa radio and LTE modem, causing some conflicts in the pin configurations. For LTE, I would suggest a GPy, as the LTE modem is connected to different pins, not causing the conflict!
              The LoRa gateway is indeed provided by the Pygate itself, which is why you can also use a Wipy on it!
              Best,
              • F Offline
                Fred administrators @jetatomic
                @jetatomic I see this is an old post but wanted to response. That is correct. The Gateway is LoRa enabled and backhaul (when using GPy) allows for cellular use or Wi-Fi. Using the POE adapter will give you Ethernet backhaul in addition. Thanks
