    LoPy To MultiTech Conduit
    25 Posts 6 Posters 10.8k Views 6 Watching
      dchappel
      Has anyone had luck establishing a consistent flow of data between LoPy and MultiTech Conduit?
      I can do an OTAA join with no problem. I have set up a simple routine to send a string every xxx seconds. However, there is usually a gap between payloads received of 1 to 6 attempts. Example output:
      The "pressure" value should be continuous from 1 to 100.
      I have experimented with time between sends (up to 5 minutes), socket data rates, etc. Nothing seems to change the situation. Like many others, I find the black box nature of the LoPy unit frustrating. The only other data that may be relevant is that I am accumulating CRC errors in the Conduit's LoRa history page:
      0_1484182782332_2017-01-11 19_57_16-MultiConnect® Conduit - Application Execution Platform.png
      Any suggestions out there from someone who might have found a way to get this to work consistently?
      For what it's worth, here are the settings available to me on the Multitech side of the Lora connection:
      0_1484182403150_2017-01-11 19_52_41-MultiConnect® Conduit - Application Execution Platform.png
      Thanks in advance for any light the community may be able to shed on this.
        cmsedore
        If you could post your code, that would help, but I usually find that this kind of problem is because the lopy hasn't been narrowed to use the subband channels that your gateway is listening on, so basically, random distribution will get you about 1 in 8 messages going through. Based on your screenshots, you're using subband 1, so if you use this function:
        def select_subband(lora, subband):
            if (type(subband) is int):
                if ((subband<1) or (subband>8)):
                    raise ValueError("subband out of range (1-8)")
                raise TypeError("subband must be 1-8")
            for channel in range(0, 72):
                lora.remove_channel(channel)
            for channel in range((subband-1)*8, ((subband-1)*8)+8):
                lora.add_channel(channel, frequency=902300000+channel*200000, dr_min=0, dr_max=3, duty_cycle=0)
        and do a:
        select_subband(lora,1)
        in your code (right after you create the lora object), it should be 100% reliable.
        -Chris
          dchappel
          Added your recommendation (which makes total sense!), but now getting this when I run:
            File "<stdin>", line 23, in <module>
            File "<stdin>", line 18, in select_subband
          TypeError: extra keyword arguments given
          Probably something simple but it's been a long day...Here's my code:
          from network import LoRa
          import binascii
          import utime
          lora = LoRa(mode=LoRa.LORAWAN, adr=False, public=True, tx_retries=0)
          app_eui = binascii.unhexlify('00 00 00 00 00 00 00 00'.replace(' ',''))
          app_key = binascii.unhexlify('00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'.replace(' ',''))
          while not lora.has_joined():
              time.sleep(5)
              print('Not yet joined...')
          if(lora.has_joined()):print("Hell Yeah!")
          s.setblocking(False)
          pressure = 1
          while lora.has_joined():
              #payload = str(pressure)
              payload = '{"pressure":'+str(pressure)+',"tst":"'+str(utime.time())+'"}'
              print(payload)
              time.sleep(5)
              s.send(payload)
              print('Joined...')
              pressure +=1
              if pressure > 100:
                  pressure = 1
            cmsedore @dchappel
            @dchappel Sorry--apparently, duty_cycle isn't supported now. Try this version of the function--I just tried your code with this change and it seems to work..
                    lora.add_channel(channel, frequency=902300000+channel*200000, dr_min=0, dr_max=3)
              dchappel @cmsedore
              @cmsedore That got it...Thanks!
              (EDIT) Or so I thought. Now LoPY hanging after a short while. Done with this for now...will pick up again when fresh. Appreciate the help.
                cmsedore
                @dchappel I found the same thing (hanging after a short while). I'm going to pull down the current firmware source and see if I can figure out what is happening. This was pretty stable in prior releases, so it may be a minor bug with the updated LoRa stack.
                  dchappel @cmsedore
                  @cmsedore Even after yesterday's firmware update LoPy still hanging after 7-8 successful sends. Have you had any luck ferreting out a bug?
                    dchappel
                    Update
                    I have come up with a workaround. The code as suggested is removing all channels and then adding back just the 8 in the sub-band. However, the LoPy locks after 7 or 8 sends. Got me thinking that it may be trying to use one of the removed channels.
                    I updated the code via brute force to put the the desired sub-band frequencies in each of the individual groups of 8 (ex. 0-7, 9-15, etc).
                    Works just fine now.
                    May just need to update so that system ignores removed channels?
                      cmsedore
                      Sorry for being slow to get back to this--other work intervened.
                      I figured out where it is hanging up, but not why just yet. Hope to run it down in the next few days.
                        cmsedore
                        Ok, I know the problem and the fix. I'll try to polish it up and do a pull request.
                        • I Offline
                          iannucci
                          Thanks for finding this -- I just ran into the same bug with my new LoPys and my Multitech Conduit. Looking forward to your fix.
                            cmsedore @iannucci
                            @iannucci I just created the pull request.
                              johncaipa @cmsedore
                              @cmsedore can you share your final code?, the last one has worked for me but it happens the same as everyone, it blocks after some successful submissions to TTN. Thanks in advance. I am using a AU915 Multitech gateway config
                                cmsedore @johncaipa
                                Hi @johncaipa, The pull request should be visible from the main repository if you'd like to patch the firmware source directly. (This can't be fixed via python code.)
                                  johncaipa @cmsedore
                                  Hi @cmsedore You give me to understand that it is a problem with the firmware? Hopefully the Pycom team will take it into account.
                                  Sorry but I do not know where the repository is, you can share the link as soon as you can, sorry for the inconvenience.
                                    livius
                                    https://github.com/pycom/pycom-micropython/pulls
                                      dchappel @johncaipa
                                      @johncaipa
                                      Until the firmware is updated, here is the workaround I came up with. Since the current firmware insists on using all the channels, this distributes the the desired sub-band frequencies among them all.
                                      It's not pretty, but it works!
                                      import binascii
                                      import utime
                                          index = (subband-1)*8
                                          for channel in range(0, 7):
                                              lora.add_channel(channel, frequency=902300000+index*200000, dr_min=0, dr_max=3)
                                              index+=1
                                          for channel in range(8, 15):
                                              index+=1
                                          for channel in range(16, 23):
                                              index+=1
                                          for channel in range(24, 31):
                                              index+=1
                                          for channel in range(32, 39):
                                              index+=1
                                          for channel in range(40, 47):
                                              index+=1
                                          for channel in range(48, 55):
                                              index+=1
                                          for channel in range(56, 63):
                                              index+=1
                                          for channel in range(64, 71):
                                              index+=1
                                      sb = 2 #Change to desired conduit frequency sub-band
                                      select_subband(lora,sb)
                                          time.sleep(5)
                                          print('Not yet joined on frequency sub-band '+str(sb)+'...')
                                      if(lora.has_joined()):print("Successful join on frequency sub-band "+str(sb)+"!")
                                      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
                                      pressure = 1
                                          payload = '{"pressure":'+str(pressure)+',"tst":'+str(utime.time())+'}'
                                          print(payload)
                                          s.send(payload)
                                          time.sleep(6)
                                          pressure +=1
                                          if pressure > 100:
                                              pressure = 1
                                        johncaipa @dchappel
                                        @dchappel do you know if the error was already corrected in the new firmware (1.5.0.b2)?
                                          dchappel
                                          I don't know if this got fixed. Haven't gone back and checked.
                                          • I Offline
                                            iannucci @dchappel
                                            @dchappel I built my own version of the firmware with this fix in it. But as this is the first time I've built ESP32 / LoPy firmware, I am having a small problem. The make process seems to work properly, and the flashing process seems to work. But when I remove the jumper wire and reboot the LoPy, it runs a different version of firmware, not the one I just flashed.
                                            I've tried the safe boot tricks to no avail.
                                            Any ideas how to get the LoPy to come up running the version of firmware just uploaded via make?
                                            • 1
                                            • 2
                                            • 2 / 2
