    Expansion Board V3.1 connecting to Raspberry Pi 3
    7 Posts 3 Posters 309 Views 3 Watching
    • Z Offline
      zmaier
      hi everyone,
      i am trying to conneect a Wipy3 on a Expansion Board3.1 to a RasPi 3 via USB. But i cannot find the device under /dev /...
      Do i have to install drivers? Which dev is it?
      Hope you can help,
      regards Martin
        protean @zmaier
        @zmaier it should show up as a generic raw tty device.
        On my system, it's called: /dev/ttyACM0.
        Can you share the output of ls -al /dev/tty*?
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zmaier @protean
          Hi, here the output, its a lot, so i skipped the beginning.
          How can i open a REPL Terminal?
          thx
          Zmaier
          crw--w---- 1 root tty 4, 57 Mai 1 20:17 /dev/tty57
          crw--w---- 1 root tty 4, 58 Mai 1 20:17 /dev/tty58
          crw--w---- 1 root tty 4, 59 Mai 1 20:17 /dev/tty59
          crw--w---- 1 root tty 4, 6 Mai 1 20:17 /dev/tty6
          crw--w---- 1 root tty 4, 60 Mai 1 20:17 /dev/tty60
          crw--w---- 1 root tty 4, 61 Mai 1 20:17 /dev/tty61
          crw--w---- 1 root tty 4, 62 Mai 1 20:17 /dev/tty62
          crw--w---- 1 root tty 4, 63 Mai 1 20:17 /dev/tty63
          crw--w---- 1 root tty 4, 7 Mai 1 20:17 /dev/tty7
          crw--w---- 1 root tty 4, 8 Mai 1 20:17 /dev/tty8
          crw--w---- 1 root tty 4, 9 Mai 1 20:17 /dev/tty9
          crw-rw---- 1 root dialout 166, 0 Mai 1 20:17 /dev/ttyACM0
          crw-rw---- 1 root dialout 204, 64 Mai 1 20:17 /dev/ttyAMA0
          crw------- 1 root root 5, 3 Mai 1 20:17 /dev/ttyprintk
          C P 2 Replies Last reply Reply Quote 0
            crumble @zmaier
            @zmaier
            The pycom device may need too much power. Plug an active hub inbetween them
            • Z Offline
              zmaier @crumble
              @crumble : The Wipy is listed in my /dev/. Why is more power needed?
                protean @zmaier
                @zmaier I don't know what terminal applications you have available, but i use minicom, personally.
                minicom -D /dev/ttyACM0 should give you a shell into the device. You can use other programs too, as documented here: https://docs.pycom.io/gettingstarted/programming/repl/serial.html
                Then you can use ctrl commands as documented here: https://docs.pycom.io/gettingstarted/programming/repl/
                It's just a pretty standard micro python environment, you can read about the REPL here: https://docs.micropython.org/en/latest/esp8266/tutorial/repl.html
                • Z Offline
                  zmaier @protean
                  @protean thx! it is working now.
