    LoPy connection error via pymakr and pycom upgrade
    2 Posts 1 Posters 189 Views 1 Watching
      pyoneer
      I have recently gotten my LoPy4 with Pysense expansion board and have been successfully working with it.
      However, at some point I messed up a program and had to do a safe reboot. Since then nothing really works anymore. When I connect the LoPy via USB it is clearly found, e.g. using lsusbin terminal I see:
      Bus 001 Device 022: ID 04d8:f012 Microchip Technology, Inc.
      The same is true for Pymakr in Atom. However, after automatically trying to establish a connection I get the error:
      Searching for PyCom boards on serial...
      Connecting to /dev/ttyACM0...
      Connection error: Error: timeout
      Nothing I've tried so far solved that problem. I also don't seem to get into safe boot. If I try to use the Pycom Upgrade Software I get the following error at the end:
      Error message in Pycom Upgrade
      Can I somehow do a hard reset or something?
      Thank you already in advance!
      Best,
      Felix
        pyoneer
        Update: I managed to get the device to do a hard reset and select the factory firmware by connecting P12+3v3 for 7-9 seconds. The LED flashed green, flashed green faster and then again green very fast. Afterwards, I disconnected the device. However, I still get the same connection error: Error: timeout.
        What is different now, is that I can run the Pycom Upgrade tool and it detects the device and performs an update: Update results
        But even afterwards: I can't access the device via Pymakr due to the same error.
        Has anybody another idea what I could do now?
        Best, Felix
