    pin.hold on gpy
    gpypin.hold
    6 Posts 2 Posters 504 Views 2 Watching
    • K Offline
      kjm
      If I run
      d='P22'; c='P21'; b='P20'; a='P19'; decode='P23'
      A=Pin(a, Pin.OUT); B=Pin(b, Pin.OUT); C=Pin(c, Pin.OUT); D=Pin(d, Pin.OUT); E=Pin(decode, Pin.IN)
      for i in (A, B, C, D, E): i.hold(0)
      everything is sweet, but if I change it to
      d='P22'; c='P21'; b='P20'; a='P19'; decode='P18'
      I get
      OSError: the hold functionality is only available for GPIO pins in the RTC domain
      Which leads me to thing the gpy thinks 'P18' is not in the rtc domain. However according to https://docs.pycom.io/firmwareapi/pycom/machine/pin.html it is?!
        robert-hh @kjm
        @kjm Maybe the error message is just wrong. You have defined P18 as input, for which pin hold is not meaningful.
        • K Offline
          kjm
          If I make 'P18' an output I get the same message Rob
            robert-hh @kjm
            @kjm Nevertheless P18 is a input only Pin (GPIO34).
            • K Offline
              kjm @robert-hh
              @robert-hh
              So if hold is appropriate for outputs only & P13-P18 are inputs only then hold is unusable with pins P13-P18?
                robert-hh @kjm
                @kjm Obviously yes.
