How can I cancel the WLan and time query after about 30 seconds without getting a connection?
  • How can I cancel the WLan and time query after about 30 seconds without getting a connection? (Restart)
    And how can you query the times that you automatically get summer or winter time.
    Can anyone help me?
    Here's my code that usually works very well.
        # W-Lan Verbindungsaufbau---------------------------------------------
        if (Verbindung) == 1:
            from network import WLAN
            wlan = WLAN(mode=WLAN.STA)
            nets = wlan.scan()
            for net in nets: #Suche nach W-Lan Netzen
                Routerwahl = 1 #Der Router aus den Settings
                print(net.ssid) #Gefundene Netzwerke
                time.sleep(0.5)
                if net.ssid == 'XXXXX': #Immer Zugang
                    Routerwahl = 2
                    time.sleep(0.5)
                if net.ssid == settings.Router or net.ssid == 'XXXXX': #Auswahl von 2 Zugängen
                    print('Netzwerk gefunden!')
                    print('Verbinde mit... ' + net.ssid)
                    if (ssd1306) == 1:
                        if (settings.Display) == 1:
                            x = OledDisplay.OledDisplay(True)
                            xo = OledGrafx.OledGrafx(True)
                            x.clear()
                            xo.PrintStrings("W-Lan Netz...","wurde gefunden","Verbindung wird","aufgebaut...")
                    if Routerwahl == 1: #Der Router aus den Settings
                        wlan.connect(net.ssid, auth=(net.sec, settings.Pass), timeout=5000)
                        while not wlan.isconnected():
                        print('WLAN-Verbindung erfolgreich!')
                        if (ssd1306) == 1:
                                x.clear()
                                xo.PrintStrings(""," Verbindung...","   O K","")
                    if Routerwahl == 2: #Immer Zugang
                        wlan.connect(net.ssid, auth=(net.sec, 'XXXXX'), timeout=5000)
                        if (ssd1306) == 1:
                                x.clear()
    # Datum und Uhrzeit vom Server holen------------------------------------------------------------------------------------
                    print("Syncing RTC to NTP...")
                    if (ssd1306) == 1:
                            x.clear()
                            xo.PrintStrings("Datum und","Uhrzeit...","wird vom","Server geholt")
                    rtc.ntp_sync("pool.ntp.org", update_period=3600) # Datum und Uhrzeit holen
                    #rtc.ntp_sync("pool.ntp.org")
                    while not rtc.synced():
                    # Startzeit
                    #print(rtc.now())
                    time1 = rtc.now() # Übergabe Datum und Uhrzeit in die Variable time1
                    startzeit = time.time()
                    LogDateTime = "{}.{:}.{:};{:0>2d}:{:0>2d}:{:0>2d}".format(time1[2], time1[1], time1[0], time1[3]+TimeDiff, time1[4], time1[5])
                    LogDate = "{}.{:}.{:}".format(time1[2], time1[1], time1[0])
                    LogTime = "{:0>2d}:{:0>2d}:{:0>2d}".format(time1[3]+TimeDiff, time1[4], time1[5])
                    print (LogDateTime)
                    break
