How can I reset the board
I'm using a wipy3 with expansion board v2.1a and it's not connecting anymore, I would like, then to hardreset it, but the tutorials I found are not working, please help
@gabicorsan Which software do you use on the PC to connect to the WiPy3? And if you say "not connecting anymore", did it connect before, and what did change?
If you want to reload the firmware with a expansion board 2, you have to connect P2 to GND manually and push the reset button, before you start the upload procedure. -
@robert-hh I was using atom, but decided to go to zerynth, but now I am not able to virtualize in zerynth and then load programs and atom doesn't recognize it anymore. Is there any way to reset to factory by the hardware?
@gabicorsan As said, you can reload the firmware with a expansion board 2, you have to connect P2 to GND manually and push the reset button, before you start the upload procedure. The documentation for doing that is here:
https://docs.pycom.io/gettingstarted/installation/firmwaretool.html
Then the WIPy3 should work as before.
