    Two restarts on pin wake from deepsleep
    2 Posts 1 Posters 163 Views 1 Watching
      thinginnovations
      I'm deep sleeping a LoPy with the following:
          machine.pin_sleep_wakeup(['P8'], mode=machine.WAKEUP_ALL_LOW, enable_pull=True)
          # 2 minutes
          machine.deepsleep(120000)
      But on wakeup via the pin P8 being taken low see this:
      ets Jun  8 2016 00:22:57
      rst:0x5 (DEEPSLEEP_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:2156
      ho 0 tail 12 room 4
      load:0x4009fa00,len:19208
      entry 0x400a05f4
      Initializing filesystem as FatFS!
      LoRaWAN sensor node
      Reset cause Deepsleep
      Wake reason (1, [Pin('P8', mode=Pin.IN, pull=Pin.PULL_DOWN, alt=-1)])
      Sleeping
      rst:0x10 (RTCWDT_RTC_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
      ho 0 tail 12 room 4
      entry 0x400a05f4
      LoRaWAN sensor node
      Reset cause Power On
      Wake reason (0, None)
      Go back to sleep
      It is waking correctly on the pin, sleeping and waking again immediately after sleeping.
      Any ideas what is going wrong here?
      Andrew
        thinginnovations
        No ideas yet?
