    Gpy + LTE Nb IoT +MQTT?
    4 Posts 2 Posters 476 Views 2 Watching
    • M Offline
      magdalena
      I'd like to send data from the Gpy board to a cloud service in the internet (via Nb IoT).
      I managed to send data to adafruit.io by using MQTT via WIFI.
      Then I tried the same thing with an LTE Nb IoT connection, but it failed. (Connection to LTE worked, sending via MQTT didn't)
      (OSError: 128)Unbenannt.PNG
      Where is my mistake?
        SiMoS-IoT @magdalena
        @magdalena I had the same problem switching from WiFi to LTE on a FiPy/Pysense. Try adding a time.sleep(1) between the client.publish and client.disconnect.
        • M Offline
          magdalena
          @SiMoS-IoT Hmm ok Error 128 is gone now
          But instead I'm getting OSError: -1
          Did you manage to solve the problem?
          If so, could you maybe upload the code that you used?
          • M Offline
            magdalena @SiMoS-IoT
